Hi, is it possible to assign two or more Lightwave Mood switches to act independently. I am hoping to connect possibly six of these to a Vera Edge all controlling different lights and scenes. I’ve seen in forums that state 111,112 codes are given but if you have two or more side by side could these be set up to more addresses. Do all the switches chuck out the same signal? New to this stuff, so hope my question is clear.
With LightwaveRF, the moods are stored within the dimmers / sockets, therefore any paired remote that sends ‘recall mood 1’ will set those dimmers / sockets to the same settings.
It is possible to setup the Vera so that it has groups of LightwaveRF devices paired using different remote ID. That way you can have mood 1-6 set independently for each group.
The alternative is to use a scene in Vera to send a sequence of individual commands to each LightwaveRF unit in turn.
However if you are using Mood switch → Vera → dimmer / socket (and not controlling the Lightwave devices directly) then each mood switch will appear in Vera as a separate device with it’s own remote ID and you can set it to trigger whatever you like.
