I have installed 3 Cooper RFWDC Scene Controllers in my home. If I had just one controller, everything seems to work fine. However, each controller works independently of the others. Therefore one controller doesn’t know what the other has activated. So if I activate scene 1 on one controller (blue light gets bright only on that controller not the other two), then my wife activates scene 3 on another controller (3rd button lights up on that controller, not the others, and the 1st button is still lit up on the one I activated). Consequently this throws all the dimmers in the house off as the scene I activated was not de-activated before my wife kicked off scene 3.
How can I make my 3 controllers work together? If I push button 1 (scene 1) on one controller, I want that same button to light up on all 3 controllers letting the use know which scene is currently active, and needs to be deactivated before a new scene is initiated?
Any help is appreciated.
Chad
