Multiple arguments in luup call
Hi all,
U just setup imperihome on a tablet and am trying to use the SayTTS stuff to call out info.
The call below works, but defaults to a mid-level volume.
luup.call_action(“urn:imperihome-com:serviceId:ImperiHomeDevice1”, “SayTTS”, {Text = “Test Text To Say”}, 44);
It seems that the parameter Volume is valid as I can pass it as 100 from the “Control” section of the imperihome device, but I can’t figure out how to call that in my script.
I have tailed the log, but it shows it setting parameters individually, and not in luup code.
Any suggestions?
I have tried:
luup.call_action(“urn:imperihome-com:serviceId:ImperiHomeDevice1”, “SayTTS”, {Text = “Test Text To Say”}, {Volume = 100},44);
luup.call_action(“urn:imperihome-com:serviceId:ImperiHomeDevice1”, “SayTTS”, {Text = “Test Text To Say”, Volume = 100},44);
and I’ve quoted the “100” in both calls.
Any ideas?
Thanks!
From a Luup syntax point of view, your second attempt is correct:
luup.call_action("urn:imperihome-com:serviceId:ImperiHomeDevice1", "SayTTS", {Text = "Test Text To Say", Volume = 100},44);
That Luup call is documented here: http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_call_action
From an Imperihome POV, I have no idea what it does with it.
