Multiple alerts conditional handling
Hello,
Sorry about the title of this topic - I wasn’t sure how to properly describe my issue.
I have a Schlage door lock and I have some alerts set up for this device in Veralite.
Alert#1 Say “Front door is open” every time the door is opened
Alert#2 Says “Bob is home” when Bob’s PIN code is used to open the door.
Then I have Tasker on my phone/tablet read out the Veralert out loud.
The problem is that when Bob uses his PIN to open the door I get both alert#1 and alert#2 at virtually the same time and Tasker is struggling to read them both.
Is there a way to NOT send alert #1 if alert #2 has been triggered ?
thanks
If you are using Notifications then the answer is NO.
Why not let Vera Alerts read out the alerts … It will do them in order.
