MQTT Client Plugin
I’m connecting to mosquitto.
before uploading the last file the connection went well.
Below my log
[code]# cat /tmp/log/cmh/LuaUPnP.log | grep SensorMqtt1
06 09/05/16 7:16:43.224 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {“Payload”:“{"ArmedTripped":0,"DeviceId":114,"DeviceName":"MKT Garagepoort","DeviceType":"urn:schemas-micasaverde-com:device:DoorSensor:1","OldArmedTripped":1,"RoomId":1,"RoomName":"1-Alarmsysteem","ServiceId":"urn:micasaverde-com:serviceId:SecuritySensor1","Time":1473052602,"Variable":"ArmedTripped"}”,“Topic”:“vera/MKT Garagepoort/ArmedTripped”} now: {“Payload”:“{"DeviceId":114,"DeviceName":"MKT Garagepoort","DeviceType":"urn:schemas-micasaverde-com:device:DoorSensor:1","OldTripped":1,"RoomId":1,"RoomName":"1-Alarmsysteem","ServiceId":"urn:micasaverde-com:serviceId:SecuritySensor1","Time":1473052603,"Tripped":0,"Variable":"Tripped"}”,“Topic”:“vera/MKT Garagepoort/Tripped”} #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x35670680>
06 09/05/16 8:17:02.452 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Disconnected now: Connected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
06 09/05/16 8:17:02.517 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 1 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
06 09/05/16 8:17:02.521 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {“Payload”:“{"DeviceId":114,"DeviceName":"MKT Garagepoort","DeviceType":"urn:schemas-micasaverde-com:device:DoorSensor:1","OldTripped":1,"RoomId":1,"RoomName":"1-Alarmsysteem","ServiceId":"urn:micasaverde-com:serviceId:SecuritySensor1","Time":1473052603,"Tripped":0,"Variable":"Tripped"}”,“Topic”:“vera/MKT Garagepoort/Tripped”} now: {“Payload”:“{"DeviceId":195,"DeviceName":"Presence","DeviceType":"urn:schemas-dcineco-com:device:MSwitch195:1","OldStatus2":0,"RoomId":12,"RoomName":"10-Location","ServiceId":"urn:dcineco-com:serviceId:MSwitch1","Status2":1,"Time":1473056222,"Variable":"Status2"}”,“Topic”:“vera/Presence/Status2”} #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
06 09/05/16 8:17:02.601 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Disconnected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
06 09/05/16 8:17:02.604 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
06 09/05/16 8:17:02.679 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {“Payload”:“{"DeviceId":195,"DeviceName":"Presence","DeviceType":"urn:schemas-dcineco-com:device:MSwitch195:1","OldStatus2":0,"RoomId":12,"RoomName":"10-Location","ServiceId":"urn:dcineco-com:serviceId:MSwitch1","Status2":1,"Time":1473056222,"Variable":"Status2"}”,“Topic”:“vera/Presence/Status2”} now: {“Payload”:“{"DeviceId":18,"DeviceName":"House Modes Plugin","DeviceType":"urn:schemas-micasaverde-com:device:HouseModes:1","HMode":1,"OldHMode":2,"RoomId":3,"RoomName":"6-System","ServiceId":"urn:micasaverde-com:serviceId:HouseModes1","Time":1473056222,"Variable":"HMode"}”,“Topic”:“vera/House Modes Plugin/HMode”} #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b376310>
50 09/05/16 8:27:02.829 luup_log:188: SensorMqtt plugin: loading library L_SensorMqtt1 … <0x2c4df680>
50 09/05/16 8:27:03.054 luup_log:188: SensorMqtt plugin: library L_SensorMqtt1 loaded <0x2c4df680>
06 09/05/16 8:27:03.157 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c4df680>
06 09/05/16 8:27:03.163 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Disconnected now: Connected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2c4df680>
06 09/05/16 8:27:03.185 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 1 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2c4df680>
06 09/05/16 8:27:08.101 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Disconnected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x334df680>
06 09/05/16 8:27:08.103 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x334df680>[/code]
[quote=“stefaanbolle, post:61, topic:190658”]I’m connecting to mosquitto.
Below my log
cat /tmp/log/cmh/LuaUPnP.log | grep SensorMqtt1[/quote]
Thanks. I appreciate the testing… I’m also using mosquito 1.4.8 for my testing and have two Vera+ units running UI7 and one Vera3 running UI5 and all are reporting over mqtt very reliably.
  1. Based upon your logs, I believe it is connecting and delivering payloads but reporting the “connection” status incorrectly.
  2. While I’m not seeing this issue on my installs, I just made one small update to the plugin to pre-allocate the “connection” status service variables to eliminate the LEAK warning on UI5 and perhaps resolve the inconsistent status reporting that you are seeing.
  3. Please upgrade to the latest plugin, INCLUDING uploading/refreshing the dependencies because they were updated too.
    4, Then grep for SensorMqtt - not SensorMqtt1 - and reload the luup engine. Copy the connection status and at least one variable change update.
Here is an example of my output, albeit on UI5:
$ ssh vera.home tail -f /var/log/cmh/LuaUPnP.log | grep SensorMqtt
09	09/05/16 8:44:05.233	JobHandler_LuaUPnP::Run device 53 MQTT Sender room 4 type urn:schemas-sensor-mqtt-se:device:SensorMqtt:1 id  parent 0/0xdadc30 upnp: 0 <0x2b27e000>
50	09/05/16 8:44:07.104	luup_log:53: SensorMqtt plugin: loading library L_SensorMqtt1 ... <0x2bbb1680>
50	09/05/16 8:44:07.175	luup_log:53: SensorMqtt plugin: library L_SensorMqtt1 loaded <0x2bbb1680>
50	09/05/16 8:44:07.176	luup_log:53: SensorMqtt:  Initializing SensorMqtt <0x2bbb1680>
06	09/05/16 8:44:07.203	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bbb1680>
50	09/05/16 8:44:07.204	luup_log:53: SensorMqtt:  Connect to MQTT, mqttServerIp: 10.0.1.220 mqttServerPort: 1883 <0x2bbb1680>
50	09/05/16 8:44:07.208	luup_log:53: SensorMqtt:  Successfully connected to broker: 10.0.1.220 on port 1883 <0x2bbb1680>
50	09/05/16 8:44:07.210	luup_log:53: SensorMqtt:  MQTT connection status changed from "Disconnected" to "Connected" <0x2bbb1680>
06	09/05/16 8:44:07.211	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Connected #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bbb1680>
06	09/05/16 8:44:07.211	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bbb1680>
06	09/05/16 8:45:37.913	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {"Payload":"{\"CurrentTemperature\":60,\"DeviceId\":47,\"DeviceName\":\"Carport Temp Sensor\",\"DeviceType\":\"urn:schemas-micasaverde-com:device:TemperatureSensor:1\",\"OldCurrentTemperature\":59,\"RoomId\":2,\"RoomName\":\"Outside\",\"ServiceId\":\"urn:upnp-org:serviceId:TemperatureSensor1\",\"Time\":1473078975,\"Variable\":\"CurrentTemperature\"}","Topic":"Vera/30002905/TemperatureSensor1/47"} now: {"Payload":"{\"DeviceId\":29,\"DeviceName\":\"Exterior Cameras (Power)\",\"DeviceType\":\"urn:schemas-upnp-org:device:BinaryLight:1\",\"OldTarget\":1,\"RoomId\":4,\"RoomName\":\"Supporting Devices & Scenes\",\"ServiceId\":\"urn:upnp-org:serviceId:SwitchPower1\",\"Target\":0,\"Time\":1473079537,\"Variable\":\"Target\"}","Topic":"Vera/30002905/SwitchPower1/29"} #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2d9b1680>
06	09/05/16 8:45:38.123	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {"Payload":"{\"DeviceId\":29,\"DeviceName\":\"Exterior Cameras (Power)\",\"DeviceType\":\"urn:schemas-upnp-org:device:BinaryLight:1\",\"OldTarget\":1,\"RoomId\":4,\"RoomName\":\"Supporting Devices & Scenes\",\"ServiceId\":\"urn:upnp-org:serviceId:SwitchPower1\",\"Target\":0,\"Time\":1473079537,\"Variable\":\"Target\"}","Topic":"Vera/30002905/SwitchPower1/29"} now: {"Payload":"{\"DeviceId\":29,\"DeviceName\":\"Exterior Cameras (Power)\",\"DeviceType\":\"urn:schemas-upnp-org:device:BinaryLight:1\",\"OldStatus\":1,\"RoomId\":4,\"RoomName\":\"Supporting Devices & Scenes\",\"ServiceId\":\"urn:upnp-org:serviceId:SwitchPower1\",\"Status\":0,\"Time\":1473079538,\"Variable\":\"Status\"}","Topic":"Vera/30002905/SwitchPower1/29"} #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9b1680>
06	09/05/16 8:48:15.157	Device_Variable::m_szValue_set device: 53 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttLastMessage was: {"Payload":"{\"DeviceId\":29,\"DeviceName\":\"Exterior Cameras (Power)\",\"DeviceType\":\"urn:schemas-upnp-org:device:BinaryLight:1\",\"OldStatus\":1,\"RoomId\":4,\"RoomName\":\"Supporting Devices & Scenes\",\"ServiceId\":\"urn:upnp-org:serviceId:SwitchPower1\",\"Status\":0,\"Time\":1473079538,\"Variable\":\"Status\"}","Topic":"Vera/30002905/SwitchPower1/29"} now: {"Payload":"{\"CurrentLevel\":90,\"DeviceId\":46,\"DeviceName\":\"Carport Motion Sensor\",\"DeviceType\":\"urn:schemas-micasaverde-com:device:MotionSensor:1\",\"OldCurrentLevel\":89,\"RoomId\":2,\"RoomName\":\"Outside\",\"ServiceId\":\"urn:micasaverde-com:serviceId:HumiditySensor1\",\"Time\":1473079695,\"Variable\":\"CurrentLevel\"}","Topic":"Vera/30002905/HumiditySensor1/46"} #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9b1680>
Thanks again for the testing and feedback.
Thanks a lot Blacey!
The connection still reports “disconnected”.
After reloading LUUP it becomes connected for a second and then returns disconnected.
Below some log lines
06 09/05/16 15:43:55.102 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Disconnected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x32f37680> 06 09/05/16 15:43:55.103 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x32f37680> root@MiOS_30105293:/tmp/log/cmh# cat LuaUPnP.log | grep SensorMqtt 09 09/05/16 15:42:51.361 JobHandler_LuaUPnP::Run device 188 MQTT Publish room 4 type urn:schemas-sensor-mqtt-se:device:SensorMqtt:1 cat 3:-1 id parent 0/0x9fa4b0 upnp: 0 plugin:0 pnp:0 mac: ip: <0x2b9e3310> 09 09/05/16 15:43:23.792 JobHandler_LuaUPnP::Run device 188 MQTT Publish room 4 type urn:schemas-sensor-mqtt-se:device:SensorMqtt:1 cat 3:-1 id parent 0/0x101d4b0 upnp: 0 plugin:0 pnp:0 mac: ip: <0x2b4f6310> 50 09/05/16 15:43:49.819 luup_log:188: SensorMqtt plugin: loading library L_SensorMqtt1 ... <0x2bf37680> 50 09/05/16 15:43:49.947 luup_log:188: SensorMqtt plugin: library L_SensorMqtt1 loaded <0x2bf37680> 50 09/05/16 15:43:49.948 luup_log:188: SensorMqtt: Initializing SensorMqtt <0x2bf37680> 06 09/05/16 15:43:49.987 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2bf37680> 50 09/05/16 15:43:49.988 luup_log:188: SensorMqtt: Connect to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883 <0x2bf37680> 50 09/05/16 15:43:49.991 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x2bf37680> 50 09/05/16 15:43:49.992 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2bf37680> 06 09/05/16 15:43:49.993 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Disconnected now: Connected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2bf37680> 06 09/05/16 15:43:50.016 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 1 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2bf37680> 50 09/05/16 15:43:55.101 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x32f37680> 06 09/05/16 15:43:55.102 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Disconnected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x32f37680> 06 09/05/16 15:43:55.103 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x32f37680> 09 09/05/16 15:49:45.408 JobHandler_LuaUPnP::Run device 188 MQTT Publish room 4 type urn:schemas-sensor-mqtt-se:device:SensorMqtt:1 cat 3:-1 id parent 0/0xeb94b0 upnp: 0 plugin:0 pnp:0 mac: ip: <0x2b731310> 50 09/05/16 15:50:11.513 luup_log:188: SensorMqtt plugin: loading library L_SensorMqtt1 ... <0x2c173680> 50 09/05/16 15:50:11.627 luup_log:188: SensorMqtt plugin: library L_SensorMqtt1 loaded <0x2c173680> 50 09/05/16 15:50:11.637 luup_log:188: SensorMqtt: Initializing SensorMqtt <0x2c173680> 06 09/05/16 15:50:11.718 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c173680> 50 09/05/16 15:50:11.719 luup_log:188: SensorMqtt: Connect to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883 <0x2c173680> 50 09/05/16 15:50:11.728 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x2c173680> 50 09/05/16 15:50:11.730 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2c173680> 06 09/05/16 15:50:11.730 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Disconnected now: Connected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2c173680> 06 09/05/16 15:50:11.763 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 0 now: 1 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2c173680> 50 09/05/16 15:50:16.103 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x33173680> 06 09/05/16 15:50:16.104 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerStatus was: Connected now: Disconnected #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x33173680> 06 09/05/16 15:50:16.106 Device_Variable::m_szValue_set device: 188 service: urn:upnp-sensor-mqtt-se:serviceId:SensorMqtt1 variable: mqttServerConnected was: 1 now: 0 #hooks: 1 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x33173680>
[quote=“stefaanbolle, post:63, topic:190658”]Thanks a lot Blacey!
After reloading LUUP it becomes connected for a second and then returns disconnected.[/quote]
Ok, I just pushed another update that will report debug log messages when Verbose logging is enabled on the Vera. Please do the following so we can figure this out:
  1. Enable Verbose logging on your Vera Controller
  2. Install the latest plugin (only the L_SensorMqtt1.lua and I_SensorMqtt1.xml changed)
  3. Collect logs using grep '\(^01\|^02\|^35\|^50\).*SensorMqtt'
  4. Report results here. Note, it will be easier to read the logs if you post them as code blocks.
Also, please provide your Mosquitto and Vera Firmware versions.
Thanks. Looking forward to figuring out this mystery.
Here is a sample of what we should see:
50	09/05/16 11:38:03.143	luup_log:53: SensorMqtt: Loading plugin module L_SensorMqtt1 ... <0x2b951680>
50	09/05/16 11:38:03.208	luup_log:53: SensorMqtt: Plugin module L_SensorMqtt1 loaded <0x2b951680>
50	09/05/16 11:38:03.209	luup_log:53: SensorMqtt: Initializing SensorMqtt <0x2b951680>
50	09/05/16 11:38:03.237	luup_log:53: SensorMqtt: Connecting to MQTT, mqttServerIp: 10.0.1.220 mqttServerPort: 1883... <0x2b951680>
50	09/05/16 11:38:03.239	luup_log:53: SensorMqtt: Successfully connected to broker: 10.0.1.220 on port 1883 <0x2b951680>
35	09/05/16 11:38:03.242	luup_log:53: SensorMqtt: setConnectionStatus:  currentStatus = true previousStatus = false <0x2b951680>
50	09/05/16 11:38:03.242	luup_log:53: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2b951680>
35	09/05/16 11:38:03.261	luup_log:53: SensorMqtt: ************************************************ MQTT Settings ************************************************ <0x2b951680>
35	09/05/16 11:38:03.261	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:HVAC_OperatingState1 on variable ModeState with label ModeState <0x2b951680>
35	09/05/16 11:38:03.262	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:HVAC_OperatingState1 on variable ModeStateForEnergy with label ModeStateForEnergy <0x2b951680>
35	09/05/16 11:38:03.263	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:HVAC_UserOperatingMode1 on variable ModeStatus with label ModeStatus <0x2b951680>
35	09/05/16 11:38:03.264	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:HVAC_UserOperatingMode1 on variable ModeTarget with label ModeTarget <0x2b951680>
35	09/05/16 11:38:03.265	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:HVAC_UserOperatingMode1 on variable EnergyModeStatus with label EnergyModeStatus <0x2b951680>
35	09/05/16 11:38:03.266	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:HVAC_UserOperatingMode1 on variable EnergyModeTarget with label EnergyModeTarget <0x2b951680>
35	09/05/16 11:38:03.267	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:TemperatureSensor1 on variable CurrentTemperature with label CurrentTemperature <0x2b951680>
35	09/05/16 11:38:03.270	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:EnergyMetering1 on variable Watts with label Watts <0x2b951680>
35	09/05/16 11:38:03.275	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:EnergyMetering1 on variable UserSuppliedWattage with label UserSuppliedWattage <0x2b951680>
35	09/05/16 11:38:03.281	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:GenericSensor1 on variable CurrentLevel with label CurrentLevel <0x2b951680>
35	09/05/16 11:38:03.282	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:SwitchPower1 on variable Status with label Status <0x2b951680>
35	09/05/16 11:38:03.289	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:SwitchPower1 on variable Target with label Target <0x2b951680>
35	09/05/16 11:38:03.296	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:HaDevice1 on variable BatteryLevel with label BatteryLevel <0x2b951680>
35	09/05/16 11:38:03.308	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:HumiditySensor1 on variable CurrentLevel with label CurrentLevel <0x2b951680>
35	09/05/16 11:38:03.310	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:TemperatureSetpoint1_Cool on variable CurrentSetpoint with label CurrentSetpoint <0x2b951680>
35	09/05/16 11:38:03.311	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:TemperatureSetpoint1_Cool on variable SetpointTarget with label SetpointTarget <0x2b951680>
35	09/05/16 11:38:03.312	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:LightSensor1 on variable CurrentLevel with label CurrentLevel <0x2b951680>
35	09/05/16 11:38:03.313	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable ArmedTripped with label ArmedTripped <0x2b951680>
35	09/05/16 11:38:03.316	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Tripped with label Tripped <0x2b951680>
35	09/05/16 11:38:03.318	luup_log:53: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Armed with label Armed <0x2b951680>
35	09/05/16 11:38:03.320	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:TemperatureSetpoint1_Heat on variable CurrentSetpoint with label CurrentSetpoint <0x2b951680>
35	09/05/16 11:38:03.321	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:TemperatureSetpoint1_Heat on variable SetpointTarget with label SetpointTarget <0x2b951680>
35	09/05/16 11:38:03.322	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:Dimming1 on variable LoadLevelTarget with label LoadLevelTarget <0x2b951680>
35	09/05/16 11:38:03.325	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:Dimming1 on variable LoadLevelStatus with label LoadLevelStatus <0x2b951680>
35	09/05/16 11:38:03.328	luup_log:53: SensorMqtt: Watching urn:upnp-org:serviceId:HVAC_FanOperatingMode1 on variable Mode with label Mode <0x2b951680>
35	09/05/16 11:38:49.913	luup_log:53: SensorMqtt: Watch event - device: 19 variable: Watts value 40 => 36 <0x2b751680>
50	09/05/16 11:38:49.917	luup_log:53: SensorMqtt: Sending [Living Room Lamp] Watts changed to 36 from 40 on topic Vera/30002905/EnergyMetering1/19 <0x2b751680>
35	09/05/16 11:38:49.918	luup_log:53: SensorMqtt: Publish topic: Vera/30002905/EnergyMetering1/19 message:{"DeviceId":19,"DeviceName":"Living Room Lamp","DeviceType":"urn:schemas-upnp-org:device:DimmableLight:1","OldWatts":40,"RoomId":8,"RoomName":"Living Room","ServiceId":"urn:micasaverde-com:serviceId:EnergyMetering1","Time":1473089929,"Variable":"Watts","Watts":36} <0x2b751680>
35	09/05/16 11:38:49.925	luup_log:53: SensorMqtt: Watch event - device: 19 variable: LoadLevelStatus value 40 => 36 <0x2b751680>
50	09/05/16 11:38:49.929	luup_log:53: SensorMqtt: Sending [Living Room Lamp] LoadLevelStatus changed to 36 from 40 on topic Vera/30002905/Dimming1/19 <0x2b751680>
35	09/05/16 11:38:49.929	luup_log:53: SensorMqtt: Publish topic: Vera/30002905/Dimming1/19 message:{"DeviceId":19,"DeviceName":"Living Room Lamp","DeviceType":"urn:schemas-upnp-org:device:DimmableLight:1","LoadLevelStatus":36,"OldLoadLevelStatus":40,"RoomId":8,"RoomName":"Living Room","ServiceId":"urn:upnp-org:serviceId:Dimming1","Time":1473089929,"Variable":"LoadLevelStatus"} <0x2b751680>
35	09/05/16 11:38:51.282	luup_log:53: SensorMqtt: Watch event - device: 19 variable: Watts value 36 => 5 <0x2b751680>
50	09/05/16 11:38:51.285	luup_log:53: SensorMqtt: Sending [Living Room Lamp] Watts changed to 5 from 36 on topic Vera/30002905/EnergyMetering1/19 <0x2b751680>
35	09/05/16 11:38:51.286	luup_log:53: SensorMqtt: Publish topic: Vera/30002905/EnergyMetering1/19 message:{"DeviceId":19,"DeviceName":"Living Room Lamp","DeviceType":"urn:schemas-upnp-org:device:DimmableLight:1","OldWatts":36,"RoomId":8,"RoomName":"Living Room","ServiceId":"urn:micasaverde-com:serviceId:EnergyMetering1","Time":1473089931,"Variable":"Watts","Watts":5} <0x2b751680>
35
Below the requested info:
Vera 3 with firmware 1.7.855
Mosquitto version 1.4.10 on Raspberry Pi 2B
cat /tmp/log/cmh/LuaUPnP.log | grep '\(^01\|^02\|^35\|^50\).*SensorMqtt' 50 09/06/16 8:52:37.021 luup_log:188: SensorMqtt: Loading plugin module L_SensorMqtt1 ... <0x2b9d3680> 50 09/06/16 8:52:37.187 luup_log:188: SensorMqtt: Plugin module L_SensorMqtt1 loaded <0x2b9d3680> 50 09/06/16 8:52:37.187 luup_log:188: SensorMqtt: Initializing SensorMqtt <0x2b9d3680> 50 09/06/16 8:52:37.230 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x2b9d3680> 50 09/06/16 8:52:37.233 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x2b9d3680> 50 09/06/16 8:52:37.235 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2b9d3680> 50 09/06/16 8:52:37.312 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x2b9d3680> 50 09/06/16 8:54:10.764 luup_log:188: SensorMqtt: Loading plugin module L_SensorMqtt1 ... <0x2b5a1680> 50 09/06/16 8:54:10.887 luup_log:188: SensorMqtt: Plugin module L_SensorMqtt1 loaded <0x2b5a1680> 50 09/06/16 8:54:10.908 luup_log:188: SensorMqtt: Initializing SensorMqtt <0x2b5a1680> 50 09/06/16 8:54:10.957 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x2b5a1680> 35 09/06/16 8:54:10.958 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x2b5a1680> 50 09/06/16 8:54:10.960 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x2b5a1680> 35 09/06/16 8:54:10.962 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = true previousStatus = false <0x2b5a1680> 50 09/06/16 8:54:10.963 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2b5a1680> 35 09/06/16 8:54:11.006 luup_log:188: SensorMqtt: ************************************************ MQTT Settings ************************************************ <0x2b5a1680> 35 09/06/16 8:54:11.006 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable ArmedTripped with label ArmedTripped <0x2b5a1680> 35 09/06/16 8:54:11.046 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Tripped with label Tripped <0x2b5a1680> 35 09/06/16 8:54:11.055 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Armed with label Armed <0x2b5a1680> 35 09/06/16 8:54:11.066 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:HouseModes1 on variable HMode with label HMode <0x2b5a1680> 35 09/06/16 8:54:11.068 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:HouseModes1 on variable Message with label Message <0x2b5a1680> 35 09/06/16 8:54:11.081 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status3 with label Status3 <0x2b5a1680> 35 09/06/16 8:54:11.105 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status1 with label Status1 <0x2b5a1680> 35 09/06/16 8:54:11.107 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status4 with label Status4 <0x2b5a1680> 35 09/06/16 8:54:11.108 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status2 with label Status2 <0x2b5a1680> 35 09/06/16 8:54:11.114 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventTime with label LastLogEventTime <0x2b5a1680> 35 09/06/16 8:54:11.122 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventUser with label LastLogEventUser <0x2b5a1680> 35 09/06/16 8:54:11.129 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEvent with label LastLogEvent <0x2b5a1680> 35 09/06/16 8:54:11.138 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventPartition with label LastLogEventPartition <0x2b5a1680> 35 09/06/16 8:54:11.148 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x2b5a1680> 35 09/06/16 8:54:11.148 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = true <0x2b5a1680> 50 09/06/16 8:54:11.149 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x2b5a1680> 35 09/06/16 8:54:16.103 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x325a1680> 35 09/06/16 8:54:16.104 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = false <0x325a1680> 35 09/06/16 8:54:21.103 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x325a1680> 35 09/06/16 8:54:21.104 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = false <0x325a1680> 35 09/06/16 8:54:26.104 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x325a1680> 35 09/06/16 8:54:26.104 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = false <0x325a1680> 35 09/06/16 8:54:31.012 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x325a1680> 35 09/06/16 8:54:31.013 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = false <0x325a1680> 35 09/06/16 8:54:36.103 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x325a1680> 35 09/06/16 8:54:36.104 luup_log:188: SensorMqtt: setConnectionStatus: currentStatus = false previousStatus = false <0x325a1680>
[quote=“stefaanbolle, post:65, topic:190658”]Below the requested info:
Mosquitto version 1.4.10 on Raspberry Pi 2B[/quote]
Thanks - this is very helpful. The logs that confirm it is indeed an issue with the actual connection and not an issue with incorrect connection status reporting. The way the connection state machine now works is that during plugin initialization it will attempt to connect to the broker and then process mqtt events in 5 second intervals (adequate for a persistent connection without any active subscriptions). If the connection goes down, the client will continue to check for any new mqtt events but won’t try to reconnect to the broker until it needs to publish a message; I did this intentionally because currently the client is a publish-only client but we are considering extending the client to subscribe to commands received via mqtt). The “Connection down” is reported in 5 second intervals so that is what we are seeing (every attempt to check for mqtt events fails with the connection down).
The only difference between our setups is that I am running the mqtt 1.4.8 from the ubuntu xenial PPA on an RPI 2B and I am not using an authenticated connection. I have the SensorMqtt plugin running on both 1.7.2138 on V+ and 1.5.622 on V3.
I am traveling so it is a bit difficult for me to gin up a configuration similar to yours so I have published a new version for you to test that now provides a last will and testament message in the connection request. Without the mosquito server logs, it is hard for me to know why the connection isn’t staying up (seems like the broker isn’t sending a CONNACK for some reason). Please install the latest version and see if it resolves the issue (you only need to update the L_SensorMqtt1.lua file).
If this change does not resolve the problem, it would be very helpful if you could enable debug logging on the mosquitto broker and provide the logs from both the Vera (verbose and grep provided above to include debug info). To enable logging on your RPI2, change /etc/mosquitto/mosquitto.conf to include log_type all:
log_dest file /var/log/mosquitto/mosquitto.log
log_type all
Then either kill -HUP the mosquitto process or use sudo systemctl restart mosquitto so the broker will load the new config file. Then tail -f /var/log/mosquitto/mosquitto.log on your RPI2 and restart the luup engine to reload the SensorMqtt plugin so it goes through the connection process. Finally, trigger one of your watched variables so that the client initiates a reconnect and publish.
Hopefully this will provide all the necessary detail so we can see what is going on from the broker perspective. Again, maybe you won’t need to go through these additional steps with the revised plugin but if it doesn’t work, we will need these additional details to triage further and remedy.
Thanks again for your testing…
I just thought of something else… Are you using clientid_prefixes prefix in your mosquito.conf? If so, I changed the connection request in the large robustness refactoring to include the serial number for the Vera so it is unique to each controller. The Vera will now pass ‘Vera-(SerialNumber)’ in the connection request - for example, Vera-3000299. I will change the connection log to include the ClientId that the Vera is using to establish the connection but if your broker is configured with a prefix that doesn’t match the current SensorMqtt client, then it would reject the connection request. Perhaps you can also provide your mosquitto configuration file(s) here?
I updated to the latest version.
Debug logging will be enabled later on on Mosquitto
Below my mosquitto.conf
pid_file /var/run/mosquitto.pid allow_zero_length_clientid false persistent_client_expiration 7d allow_duplicate_messages false port 1883 listener 8883 cafile /etc/mosquitto/ca.crt capath /etc/mosquitto/ certfile /etc/mosquitto/pki.crt keyfile /etc/mosquitto/pki.key tls_version tlsv1 require_certificate false persistence true persistence_location /var/lib/mosquitto/ log_dest file /var/log/mosquitto/mosquitto.log connection_messages true log_timestamp true allow_anonymous false password_file /etc/mosquitto/passwd include_dir /etc/mosquitto/conf.d
With the newest version of the plugin (reloaded LUUP + rebooted):
Mosquitto log gives:
1473173330: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting 1473173330: Config loaded from /etc/mosquitto/mosquitto.conf. 1473173330: Opening ipv4 listen socket on port 8883. 1473173330: Opening ipv6 listen socket on port 8883. 1473173330: Warning: Address family not supported by protocol 1473173330: Opening ipv4 listen socket on port 1883. 1473173330: Opening ipv6 listen socket on port 1883. 1473173330: Warning: Address family not supported by protocol 1473173340: New connection from 192.168.1.40 on port 1883. 1473173340: New client connected from 192.168.1.40 as openhab (c1, k60, u'openhab'). 1473173340: Sending CONNACK to openhab (0, 0) 1473173340: Received SUBSCRIBE from openhab 1473173340: owntracks/s7/event (QoS 0) 1473173340: openhab 0 owntracks/s7/event 1473173340: Sending SUBACK to openhab 1473173340: Received SUBSCRIBE from openhab 1473173340: /openHAB/in/+/state (QoS 0) 1473173340: openhab 0 /openHAB/in/+/state 1473173340: Sending SUBACK to openhab 1473173387: New connection from 192.168.1.251 on port 1883. root@rpi2server:/etc/mosquitto# cat /var/log/mosquitto/mosquitto.log 1473173277: Socket error on client <unknown>, disconnecting. 1473173329: Error in poll: Interrupted system call. 1473173329: mosquitto version 1.4.10 terminating 1473173330: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting 1473173330: Config loaded from /etc/mosquitto/mosquitto.conf. 1473173330: Opening ipv4 listen socket on port 8883. 1473173330: Opening ipv6 listen socket on port 8883. 1473173330: Warning: Address family not supported by protocol 1473173330: Opening ipv4 listen socket on port 1883. 1473173330: Opening ipv6 listen socket on port 1883. 1473173330: Warning: Address family not supported by protocol 1473173340: New connection from 192.168.1.40 on port 1883. 1473173340: New client connected from 192.168.1.40 as openhab (c1, k60, u'openhab'). 1473173340: Sending CONNACK to openhab (0, 0) 1473173340: Received SUBSCRIBE from openhab 1473173340: owntracks/s7/event (QoS 0) 1473173340: openhab 0 owntracks/s7/event 1473173340: Sending SUBACK to openhab 1473173340: Received SUBSCRIBE from openhab 1473173340: /openHAB/in/+/state (QoS 0) 1473173340: openhab 0 /openHAB/in/+/state 1473173340: Sending SUBACK to openhab 1473173387: New connection from 192.168.1.251 on port 1883. 1473173387: Sending CONNACK to 192.168.1.251 (0, 5) 1473173387: Socket error on client <unknown>, disconnecting. 1473173400: Received PUBLISH from openhab (d0, q0, r0, m0, '/openHAB/persist/feed', ... (17 bytes)) root@rpi2server:/etc/mosquitto# cat /var/log/mosquitto/mosquitto.log 1473173277: Socket error on client <unknown>, disconnecting. 1473173329: Error in poll: Interrupted system call. 1473173329: mosquitto version 1.4.10 terminating 1473173330: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting 1473173330: Config loaded from /etc/mosquitto/mosquitto.conf. 1473173330: Opening ipv4 listen socket on port 8883. 1473173330: Opening ipv6 listen socket on port 8883. 1473173330: Warning: Address family not supported by protocol 1473173330: Opening ipv4 listen socket on port 1883. 1473173330: Opening ipv6 listen socket on port 1883. 1473173330: Warning: Address family not supported by protocol 1473173340: New connection from 192.168.1.40 on port 1883. 1473173340: New client connected from 192.168.1.40 as openhab (c1, k60, u'openhab'). 1473173340: Sending CONNACK to openhab (0, 0) 1473173340: Received SUBSCRIBE from openhab 1473173340: owntracks/s7/event (QoS 0) 1473173340: openhab 0 owntracks/s7/event 1473173340: Sending SUBACK to openhab 1473173340: Received SUBSCRIBE from openhab 1473173340: /openHAB/in/+/state (QoS 0) 1473173340: openhab 0 /openHAB/in/+/state 1473173340: Sending SUBACK to openhab 1473173387: New connection from 192.168.1.251 on port 1883. 1473173387: Sending CONNACK to 192.168.1.251 (0, 5) 1473173387: Socket error on client <unknown>, disconnecting. 1473173400: Received PUBLISH from openhab (d0, q0, r0, m0, '/openHAB/persist/feed', ... (17 bytes)) root@rpi2server:/etc/mosquitto# cat /var/log/mosquitto/mosquitto.log 1473173277: Socket error on client <unknown>, disconnecting. 1473173329: Error in poll: Interrupted system call. 1473173329: mosquitto version 1.4.10 terminating 1473173330: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting 1473173330: Config loaded from /etc/mosquitto/mosquitto.conf. 1473173330: Opening ipv4 listen socket on port 8883. 1473173330: Opening ipv6 listen socket on port 8883. 1473173330: Warning: Address family not supported by protocol 1473173330: Opening ipv4 listen socket on port 1883. 1473173330: Opening ipv6 listen socket on port 1883. 1473173330: Warning: Address family not supported by protocol 1473173340: New connection from 192.168.1.40 on port 1883. 1473173340: New client connected from 192.168.1.40 as openhab (c1, k60, u'openhab'). 1473173340: Sending CONNACK to openhab (0, 0) 1473173340: Received SUBSCRIBE from openhab 1473173340: owntracks/s7/event (QoS 0) 1473173340: openhab 0 owntracks/s7/event 1473173340: Sending SUBACK to openhab 1473173340: Received SUBSCRIBE from openhab 1473173340: /openHAB/in/+/state (QoS 0) 1473173340: openhab 0 /openHAB/in/+/state 1473173340: Sending SUBACK to openhab 1473173387: New connection from 192.168.1.251 on port 1883. 1473173387: Sending CONNACK to 192.168.1.251 (0, 5) 1473173387: Socket error on client <unknown>, disconnecting. 1473173400: Received PUBLISH from openhab (d0, q0, r0, m0, '/openHAB/persist/feed', ... (17 bytes)) root@rpi2server:/etc/mosquitto# tail -f /var/log/mosquitto/mosquitto.log 1473173340: openhab 0 owntracks/s7/event 1473173340: Sending SUBACK to openhab 1473173340: Received SUBSCRIBE from openhab 1473173340: /openHAB/in/+/state (QoS 0) 1473173340: openhab 0 /openHAB/in/+/state 1473173340: Sending SUBACK to openhab 1473173387: New connection from 192.168.1.251 on port 1883. 1473173387: Sending CONNACK to 192.168.1.251 (0, 5) 1473173387: Socket error on client <unknown>, disconnecting.
vera log
cat /tmp/log/cmh/LuaUPnP.log | grep '\(^01\|^02\|^35\|^50\).*SensorMqtt' 35 09/06/16 16:52:55.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:00.104 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:05.118 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:10.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:15.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:20.111 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:25.116 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:30.104 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680> 35 09/06/16 16:53:35.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x32f73680>
So I can deduce what is happening, what is the IP address of the broker on your RPI and the IP address of your Vera? An earlier log showed MQTT client configured to connect to 192.168.1.40
But your RPI broker log shows that IP address is used by your openhab node.
Are you running your broker on the same IP 192.168.1.140 as OpenHab or is your broker on a different IP?
Also, it looks like Vera is on 192.168.1.251? Am I correct in deducing that?
Also, if you haven’t, please enable the debug logging on your broker by adding the two lines I posted earlier to your mosquitto.conf file (I didn’t see them in what you provided but the output looks like it was enabled). Here is what I see on my broker with log_type all enabled.
1473174909: mosquitto version 1.4.8 terminating
1473174910: mosquitto version 1.4.8 (build date Fri, 19 Feb 2016 12:03:16 +0100) starting
1473174910: Config loaded from /etc/mosquitto/mosquitto.conf.
1473174910: Opening ipv4 listen socket on port 1883.
1473174910: Opening ipv6 listen socket on port 1883.
1473174910: Bridge local.brookside doing local SUBSCRIBE on topic Vera/#
1473174910: Connecting bridge brookside-to-mqtt (mqtt.blacey.com:8883)
1473174910: Bridge brookside sending CONNECT
1473174910: Received CONNACK on connection local.brookside.
1473174910: Bridge local.brookside sending UNSUBSCRIBE (Mid: 95, Topic: Vera/#)
1473174910: Received PUBACK from local.brookside (Mid: 94)
1473174910: Received UNSUBACK from local.brookside
1473174923: New connection from 10.0.1.225 on port 1883.
1473174923: New client connected from 10.0.1.225 as Vera-30002905 (c1, k60).
1473174923: Sending CONNACK to Vera-30002905 (0, 0)
1473174923: Received PUBLISH from Vera-30002905 (d0, q0, r0, m0, 'Vera/30002905/SwitchPower1/19', ... (255 bytes))
1473174923: Sending PUBLISH to local.brookside (d0, q0, r0, m0, 'Vera/30002905/SwitchPower1/19', ... (255 bytes))
1473174923: Received PUBLISH from Vera-30002905 (d0, q0, r0, m0, 'Vera/30002905/EnergyMetering1/19', ... (262 bytes))
1473174923: Sending PUBLISH to local.brookside (d0, q0, r0, m0, 'Vera/30002905/EnergyMetering1/19', ... (262 bytes))
1473174992: Received PINGREQ from Vera-30002905
1473174992: Sending PINGRESP to Vera-30002905
Finally, during your test, please poke your Vera to publishing a message by tripping or changing one of the watched variables - that will cause the Vera to try to connect again (perhaps you did in your last test?)
Stefan, I would also like to confirm that we are working with the same version of the dependencies. Please compute the md5 checksums as follows:
root@MiOS_30002905:~# openssl dgst -md5 /usr/lib/lua/mqtt_library.lua
MD5(/usr/lib/lua/mqtt_library.lua)= d277c620e1d55b6981c905d0a336216f
root@MiOS_30002905:~# openssl dgst -md5 /usr/lib/lua/utility.lua
MD5(/usr/lib/lua/utility.lua)= 178cf5910a31768703efecf744691700
All of that said, I plan to make some changes but they won’t change these results here:
[ul][li]Log the MQTT client id used by the SensorMqtt plugin[/li]
[li]Add the MQTT client id to the Settings tab[/li]
[li]Change the connection model to attempt reconnect based upon a user-supplied reconnect-interval (currently it only tries to reconnect when it publishes a message because the client is only a publisher but this change will be needed in the future when the SensorMqtt client also becomes a subscriber)[/li][/ul]
Looking forward to your reply with additional details!
My openhab 1.8.3 is running on 192.168.1.40
Mosquitto is also running on 192.168.1.40
Vera is 192.168.1.251
log_type all is set in mosquitto.
pid_file /var/run/mosquitto.pid allow_zero_length_clientid false persistent_client_expiration 7d allow_duplicate_messages false port 1883 listener 8883 cafile /etc/mosquitto/ca.crt capath /etc/mosquitto/ certfile /etc/mosquitto/pki.crt keyfile /etc/mosquitto/pki.key tls_version tlsv1 require_certificate false persistence true persistence_location /var/lib/mosquitto/ log_dest file /var/log/mosquitto/mosquitto.log log_type all connection_messages true log_timestamp true allow_anonymous false password_file /etc/mosquitto/passwd include_dir /etc/mosquitto/conf.d
Below my logs
Mosquitto
1473230930: Sending PINGRESP to openhab 1473230983: Error in poll: Interrupted system call. 1473230983: mosquitto version 1.4.10 terminating 1473230983: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting 1473230983: Config loaded from /etc/mosquitto/mosquitto.conf. 1473230983: Opening ipv4 listen socket on port 8883. 1473230983: Opening ipv6 listen socket on port 8883. 1473230983: Warning: Address family not supported by protocol 1473230983: Opening ipv4 listen socket on port 1883. 1473230983: Opening ipv6 listen socket on port 1883. 1473230983: Warning: Address family not supported by protocol 1473231011: New connection from 192.168.1.251 on port 1883. 1473231011: Sending CONNACK to 192.168.1.251 (0, 5) 1473231011: Socket error on client <unknown>, disconnecting. 1473231018: New connection from 192.168.1.40 on port 1883. 1473231018: New client connected from 192.168.1.40 as openhab (c1, k60, u'openhab'). 1473231018: Sending CONNACK to openhab (0, 0) 1473231031: New connection from 192.168.1.251 on port 1883. 1473231031: Sending CONNACK to 192.168.1.251 (0, 5) 1473231031: Socket error on client <unknown>, disconnecting. 1473231031: New connection from 192.168.1.251 on port 1883. 1473231031: Sending CONNACK to 192.168.1.251 (0, 5) 1473231031: Socket error on client <unknown>, disconnecting. 1473231031: New connection from 192.168.1.251 on port 1883. 1473231031: Sending CONNACK to 192.168.1.251 (0, 5) 1473231031: Socket error on client <unknown>, disconnecting. 1473231031: New connection from 192.168.1.251 on port 1883. 1473231031: Sending CONNACK to 192.168.1.251 (0, 5) 1473231031: Socket error on client <unknown>, disconnecting. 1473231032: New connection from 192.168.1.251 on port 1883. 1473231032: Sending CONNACK to 192.168.1.251 (0, 5) 1473231032: Socket error on client <unknown>, disconnecting. 1473231048: Received SUBSCRIBE from openhab 1473231048: owntracks/s7/event (QoS 0) 1473231048: openhab 0 owntracks/s7/event 1473231048: Sending SUBACK to openhab 1473231050: Received SUBSCRIBE from openhab
vera
50 09/07/16 8:50:11.700 luup_log:188: SensorMqtt: Loading plugin module L_SensorMqtt1 ... <0x2c2eb680> 50 09/07/16 8:50:11.842 luup_log:188: SensorMqtt: Plugin module L_SensorMqtt1 loaded <0x2c2eb680> 50 09/07/16 8:50:11.842 luup_log:188: SensorMqtt: Initializing SensorMqtt <0x2c2eb680> 50 09/07/16 8:50:11.868 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x2c2eb680> 35 09/07/16 8:50:11.869 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x2c2eb680> 50 09/07/16 8:50:11.872 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x2c2eb680> 50 09/07/16 8:50:11.873 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x2c2eb680> 35 09/07/16 8:50:11.898 luup_log:188: SensorMqtt: ************************************************ MQTT Settings ************************************************ <0x2c2eb680> 35 09/07/16 8:50:11.899 luup_log:188: SensorMqtt: Watching urn:akbooer-com:serviceId:Netatmo1 on variable LastUpdated with label LastUpdated <0x2c2eb680> 35 09/07/16 8:50:11.906 luup_log:188: SensorMqtt: Watching urn:akbooer-com:serviceId:Netatmo1 on variable Timestamp with label Timestamp <0x2c2eb680> 35 09/07/16 8:50:11.913 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventTime with label LastLogEventTime <0x2c2eb680> 35 09/07/16 8:50:11.921 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventUser with label LastLogEventUser <0x2c2eb680> 35 09/07/16 8:50:11.928 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEvent with label LastLogEvent <0x2c2eb680> 35 09/07/16 8:50:11.936 luup_log:188: SensorMqtt: Watching urn:futzle-com:serviceId:CaddxNX584Security1 on variable LastLogEventPartition with label LastLogEventPartition <0x2c2eb680> 35 09/07/16 8:50:11.943 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status3 with label Status3 <0x2c2eb680> 35 09/07/16 8:50:11.945 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status1 with label Status1 <0x2c2eb680> 35 09/07/16 8:50:11.947 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status4 with label Status4 <0x2c2eb680> 35 09/07/16 8:50:11.948 luup_log:188: SensorMqtt: Watching urn:dcineco-com:serviceId:MSwitch1 on variable Status2 with label Status2 <0x2c2eb680> 35 09/07/16 8:50:11.950 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:HouseModes1 on variable HMode with label HMode <0x2c2eb680> 35 09/07/16 8:50:11.951 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:HouseModes1 on variable Message with label Message <0x2c2eb680> 35 09/07/16 8:50:11.953 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable ArmedTripped with label ArmedTripped <0x2c2eb680> 35 09/07/16 8:50:11.960 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Tripped with label Tripped <0x2c2eb680> 35 09/07/16 8:50:11.968 luup_log:188: SensorMqtt: Watching urn:micasaverde-com:serviceId:SecuritySensor1 on variable Armed with label Armed <0x2c2eb680> 35 09/07/16 8:50:11.976 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x2c2eb680> 50 09/07/16 8:50:11.977 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x2c2eb680> 35 09/07/16 8:50:16.119 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:21.105 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:26.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:31.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:31.488 luup_log:188: SensorMqtt: Watch event - device: 151 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.502 luup_log:188: SensorMqtt: Sending [Living - Humidity] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.503 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":151,"DeviceName":"Living - Humidity","DeviceType":"urn:schemas-micasaverde-com:device:HumiditySensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.503 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x32ceb680> 35 09/07/16 8:50:31.504 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x32ceb680> 50 09/07/16 8:50:31.507 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x32ceb680> 50 09/07/16 8:50:31.508 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x32ceb680> 35 09/07/16 8:50:31.591 luup_log:188: SensorMqtt: Watch event - device: 152 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.594 luup_log:188: SensorMqtt: Sending [Living - Temperature] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.595 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":152,"DeviceName":"Living - Temperature","DeviceType":"urn:schemas-micasaverde-com:device:TemperatureSensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 02 09/07/16 8:50:31.596 luup_log:188: SensorMqtt: Unable to publish, connection down. Discarding message: {"DeviceId":152,"DeviceName":"Living - Temperature","DeviceType":"urn:schemas-micasaverde-com:device:TemperatureSensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.597 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x32ceb680> 35 09/07/16 8:50:31.696 luup_log:188: SensorMqtt: Watch event - device: 153 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.699 luup_log:188: SensorMqtt: Sending [Living - Pressure] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.700 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":153,"DeviceName":"Living - Pressure","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.701 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x32ceb680> 35 09/07/16 8:50:31.701 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x32ceb680> 50 09/07/16 8:50:31.705 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x32ceb680> 50 09/07/16 8:50:31.706 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x32ceb680> 35 09/07/16 8:50:31.771 luup_log:188: SensorMqtt: Watch event - device: 177 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.774 luup_log:188: SensorMqtt: Sending [Living - Noise] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.774 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":177,"DeviceName":"Living - Noise","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 02 09/07/16 8:50:31.776 luup_log:188: SensorMqtt: Unable to publish, connection down. Discarding message: {"DeviceId":177,"DeviceName":"Living - Noise","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.777 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x32ceb680> 35 09/07/16 8:50:31.832 luup_log:188: SensorMqtt: Watch event - device: 178 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.835 luup_log:188: SensorMqtt: Sending [Living - CO2] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.836 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":178,"DeviceName":"Living - CO2","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.837 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x32ceb680> 35 09/07/16 8:50:31.837 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x32ceb680> 50 09/07/16 8:50:31.840 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x32ceb680> 50 09/07/16 8:50:31.841 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x32ceb680> 35 09/07/16 8:50:31.902 luup_log:188: SensorMqtt: Watch event - device: 156 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.905 luup_log:188: SensorMqtt: Sending [regenmeter - Rain] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.906 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":156,"DeviceName":"regenmeter - Rain","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 02 09/07/16 8:50:31.907 luup_log:188: SensorMqtt: Unable to publish, connection down. Discarding message: {"DeviceId":156,"DeviceName":"regenmeter - Rain","DeviceType":"urn:akbooer-com:device:NetatmoMetric:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.908 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x32ceb680> 35 09/07/16 8:50:31.939 luup_log:188: SensorMqtt: Watch event - device: 157 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:31.943 luup_log:188: SensorMqtt: Sending [Tuin - Humidity] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:31.944 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":157,"DeviceName":"Tuin - Humidity","DeviceType":"urn:schemas-micasaverde-com:device:HumiditySensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:31.944 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x32ceb680> 35 09/07/16 8:50:31.945 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x32ceb680> 50 09/07/16 8:50:31.948 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x32ceb680> 50 09/07/16 8:50:31.949 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x32ceb680> 35 09/07/16 8:50:31.992 luup_log:188: SensorMqtt: Watch event - device: 158 variable: LastUpdated value 1473230501 => 1473231031 <0x32ceb680> 50 09/07/16 8:50:32.002 luup_log:188: SensorMqtt: Sending [Tuin - Temperature] LastUpdated changed to 1473231031 from 1473230501 on topic {} <0x32ceb680> 35 09/07/16 8:50:32.003 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":158,"DeviceName":"Tuin - Temperature","DeviceType":"urn:schemas-micasaverde-com:device:TemperatureSensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 02 09/07/16 8:50:32.005 luup_log:188: SensorMqtt: Unable to publish, connection down. Discarding message: {"DeviceId":158,"DeviceName":"Tuin - Temperature","DeviceType":"urn:schemas-micasaverde-com:device:TemperatureSensor:1","LastUpdated":1473231031,"OldLastUpdated":1473230501,"RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231031,"Variable":"LastUpdated"} <0x32ceb680> 50 09/07/16 8:50:32.006 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x32ceb680> 35 09/07/16 8:50:32.127 luup_log:188: SensorMqtt: Watch event - device: 150 variable: Timestamp value Wed 08:41 => Wed 08:50 <0x32ceb680> 50 09/07/16 8:50:32.131 luup_log:188: SensorMqtt: Sending [Netatmo] Timestamp changed to Wed 08:50 from Wed 08:41 on topic {} <0x32ceb680> 35 09/07/16 8:50:32.131 luup_log:188: SensorMqtt: Publish topic: {} message:{"DeviceId":150,"DeviceName":"Netatmo","DeviceType":"urn:akbooer-com:device:Netatmo:1","OldTimestamp":"Wed 08:41","RoomId":9,"RoomName":"3-Netatmo","ServiceId":"urn:akbooer-com:serviceId:Netatmo1","Time":1473231032,"Timestamp":"Wed 08:50","Variable":"Timestamp"} <0x32ceb680> 50 09/07/16 8:50:32.132 luup_log:188: SensorMqtt: Connecting to MQTT, mqttServerIp: 192.168.1.40 mqttServerPort: 1883... <0x32ceb680> 35 09/07/16 8:50:32.133 luup_log:188: SensorMqtt: Authenticating with username: openhab <0x32ceb680> 50 09/07/16 8:50:32.136 luup_log:188: SensorMqtt: Successfully connected to broker: 192.168.1.40 on port 1883 <0x32ceb680> 50 09/07/16 8:50:32.137 luup_log:188: SensorMqtt: MQTT connection status changed from "Disconnected" to "Connected" <0x32ceb680> 35 09/07/16 8:50:36.125 luup_log:188: SensorMqtt: Connection down: socket_client:receive(): closed <0x332eb680> 50 09/07/16 8:50:36.126 luup_log:188: SensorMqtt: MQTT connection status changed from "Connected" to "Disconnected" <0x332eb680> 35 09/07/16 8:50:41.106 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:46.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:51.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:50:56.105 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:01.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:06.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:11.116 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:16.108 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:21.129 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:26.105 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680> 35 09/07/16 8:51:31.115 luup_log:188: SensorMqtt: Connection down: /usr/lib/lua/mqtt_library.lua:382: MQTT.client:handler(): Not connected <0x332eb680>
checksums (just reuploaded latest download from github page)
MD5(/usr/lib/lua/mqtt_library.lua)= d277c620e1d55b6981c905d0a336216f MD5(/usr/lib/lua/utility.lua)= 9bb0529b5a3d4368376a37ba9453dc4f
[quote=“stefaanbolle, post:71, topic:190658”]My openhab 1.8.3 is running on 192.168.1.40
Below my logs
Mosquitto
vera
MD5(/usr/lib/lua/mqtt_library.lua)= d277c620e1d55b6981c905d0a336216f MD5(/usr/lib/lua/utility.lua)= 9bb0529b5a3d4368376a37ba9453dc4f[/quote]
After seeing this, I went back and scrubbed/inspected each and every client authentication step and found a typo in the variable name for the mqtt broker password! I have fixed that typo, added the mqtt client id to the info logging and committed the changes to git.
Please try the latest version of the plugin on GitHub including the dependency utility.lua (I didn’t update it but your checksum doesn’t match the GitHub checksum so perhaps you missed this one when I upgraded SensorMqtt to use the Paho 0.3 mqtt lua client. Here are the checksums for everything.
[code]
$ find . -type f -not -path ‘./.git/*’ -exec openssl dgst -md5 {} ;
MD5(./Dependencies/usr/lib/lua/JSON.lua)= 7df77af31f3854a8db9dc82fcf789dea
MD5(./Dependencies/usr/lib/lua/mqtt_library.lua)= d277c620e1d55b6981c905d0a336216f
MD5(./Dependencies/usr/lib/lua/utility.lua)= 70673ff99bbc4015803facd6fe6687b5
MD5(./Plugin/D_SensorMqtt1.json)= c7d8b12e2e5fe2d61edfd614b815f9e1
MD5(./Plugin/D_SensorMqtt1.xml)= 4326276bc240949c9914fb8bb1043c6b
MD5(./Plugin/I_SensorMqtt1.xml)= 3ff8c0074b14a9908586d70c3e507fc1
MD5(./Plugin/J_SensorMqtt1.js)= 5d63ee1c3e28221be85dea901c4a0993
MD5(./Plugin/L_SensorMqtt1.lua)= 9dce0494565d602abf15a89110aa27f5
MD5(./Plugin/S_SensorMqtt1.xml)= 23bc8fa230b8be8c29b130d6f9ce95c0
[code]
I really, really appreciate your patience in running numerous tests. Had I not been traveling, I would have set up an authenticated broker instance running 1.4.10 to mimic your config and dug in to find this on my own. I’m pretty sure we nailed it though and thanks again for all your help and patience![/code]
Hi Blacey, guess what…
MQTT IP: 192.168.1.40 MQTT Port: 1883 MQTT User: openhab MQTT Status: Connected MQTT Last Message: {"Payload":"{\"DeviceId\":150,\"DeviceName\":\"Netatmo\",\"DeviceType\":\"urn:akbooer-com:device:Netatmo:1\",\"OldTimestamp\":\"Wed 15:00\",\"RoomId\":9,\"RoomName\":\"3-Netatmo\",\"ServiceId\":\"urn:akbooer-com:serviceId:Netatmo1\",\"Time\":1473253666,\"Timestamp\":\"Wed 15:07\",\"Variable\":\"Timestamp\"}","Topic":"{}"}
I think the problem has been solved. Connection is established!
Thanks a lot for your support and quick response!
I’m looking forward to further developments of your plugin and I’m certainly willing to test if it can help you.
Subscribing to mqtt broker for reading values can be a great update since this could open the door to owntracks integration.
[quote=“stefaanbolle, post:73, topic:190658”]I think the problem has been solved. Connection is established!
Subscribing to mqtt broker for reading values can be a great update since this could open the door to owntracks integration.[/quote]
Awesome! :slight_smile: :slight_smile: :slight_smile: Thanks for your diligent and methodical testing and feedback.
Feel free to outline the owntracks use case that you envision to influence the direction of the plugin. :wink:
Owntracks reports it’s status/presence on Android/iOS using mqtt to a mqtt broker.
It would be great if a plugin in Vera would allow to use owntracks as presence tracker (kind of iphone locator plugin) and additionally shows any monitored device (ie kids) on a map in vera.
That’s in short my usecase.
Interesting Work! :smiley:
Would it be possible to share the Node-Red flow?
I got the plugin working. I documented the steps below. This guide assumes you have installed a MQTT-broker on a remote Raspberry Pi. The MQTT-Broker I’m using is Mosquitto. Check out How-To Get Started with Mosquitto MQTT Broker on a Raspberry Pi - YouTube for instructions on how to install it.
[code]#1 Download the zip from GitHub - jonferreira/vera-mqtt to my MacBook
#2 Copy the Dependency-files to the Vera
#2.1 Terminal
#2.2 cd ~/Downloads/
#2.3 scp vera-mqtt-master.zip root@vera:
#2.4 ssh root@vera
#2.5 unzip vera-mqtt-master.zip
#2.6 cp vera-mqtt-master/Dependencies/usr/lib/lua/* /usr/lib/lua/
#3 Copy the Plugin-files to the Vera
#3.1 Terminal
#3.1.2 unzip vera-mqtt-master.zip
#3.2 Start up your FireFox-browser
#3.2.1 http://vera/cmh/#develop_apps
#3.2.2 Luup files → Upload
#3.2.3 Select all files in the unpacked vera-mqtt-master/Plugin directory
#4 Create a new Device using the newly uploaded Plugin-files
http://vera/cmh/#develop_apps → Create device →
Description = “MQTT client”
Upnp Device FileName = “D_SensorMqtt1.xml”
Upnp Implementation Filename = “I_SensorMqtt1.xml”
→ Create device
#5 Reload luup
http://vera:3480/data_request?id=reload
#6 Wait a few moments, and the newly created device will popup at http://vera/cmh/#devices
However, the device fails with the error messsage “MQTT client[189]: Startup Lua Failed”
Okey, so we need to peek in the logs on the Vera
 ssh root@vera
Doh! Reading the error message you now realize that you need to configure the plugin :stuck_out_tongue:
#7 http://vera/cmh/#devices → MQTT client → Advanced → Variables tab
mqttServerIp = Raspberry_ip
mqttServerPort = 1883
mqttServerUser = username
mqttServerPassword = password
#8 Start a subscriber on the Raspberry, and verify the credentials you have provided above
mosquitto_sub -h 127.0.0.1 -p 1883 -u username -P password -t Vera/#
mosquitto_pub -h 127.0.0.1 -p 1883 -u username -P password -t Vera/Event/DeviceAlias -m “qwerty”
#9 Start pushing event changes from Vera-attached devices
 http://vera/cmh/#devices -> MQTT client -> WatchDog -> and checkbox the following
   * urn:upnp-org:serviceId:TemperatureSensor1     CurrentTemperature  CurrentTemperature
   * urn:micasaverde-com:serviceId:HumiditySensor1 CurrentLevel        CurrentLevel
   * urn:upnp-org:serviceId:SwitchPower1           Status              Status
   -> Save Changes
#10 Reload luup
#11 Go into the Vera-gui and toggle a lightswitch
#12 Go back to the scrubscriber that you started at step #8. You should now see the mqtt-message there.
[/code]
I got the Node-Red thing working on my Raspberry Pi 3 (RPI3). This guide assumes you have previously set up the MQTT-Broker ‘Mosquitto’ on the RPI3. Here’s how I did it:
[code]#--------------------------------
1. Install InfluxDb on the RPI3
ssh pi@raspberry_ip
sudo apt-get install apt-transport-https
curl -sL https://repos.influxdata.com/influxdb.key | sudo apt-key add - source /etc/os-release
echo “deb https://repos.influxdata.com/debian jessie stable” | sudo tee /etc/apt/sources.list.d/influxdb.list
sudo apt-get update && sudo apt-get install influxdb
sudo systemctl start influxdb
→ InfluxDb Admin gui = http://raspberry_ip:8083/
→ InfluxDb data get/set via http = http://raspberry_ip:8086/
2. Configure InfluxDb
influx
CREATE DATABASE “vera_db”
SHOW DATABASES
CREATE USER “nodered” WITH PASSWORD ‘nodered’
GRANT WRITE ON vera_db TO nodered
CREATE USER “grafana” WITH PASSWORD ‘grafana’
GRANT READ ON vera_db TO grafana
SHOW USERS
SHOW GRANTS FOR nodered
SHOW GRANTS FOR grafana
3. Install Node Red on the RPI3
(Check out http://nodered.org/docs/hardware/raspberrypi for details)
ssh pi@raspberry_ip
sudo apt-get update
sudo apt-get install nodered
sudo apt-get install npm
sudo npm install -g npm@2.x
sudo apt-get install sense-hat
sudo systemctl enable nodered.service
sudo node-red-start
-> NodeRed web gui = http://raspberry_ip:1880
4. Create the ‘flow’ in Node-Red
4.1 - Drag/Drop an MQTT-inputnode and configure it:
Server = 127.0.0.1:1883
Topic = Vera/#
QoS = 2
Name = MQTT input on topic Vera/#
4.2 - Drag/Drop a Function-Node and configure it:
Name = Function converting MQTT msg to InfluxDB-format
Outputs = 1
Function =
// 1. Retrieve incoming values from the Mosquitto-MQTT message
var Topic = msg.topic;
         var Influx_Key    = "Unknown_key";
         var Inflex_KeyTag = "Unknown_tag";
         var Influx_Value  = "Unknown_value";
         var objJson = JSON.parse(msg.payload);
         var DeviceName         = objJson.DeviceName;
         var DeviceType         = objJson.DeviceType;
         var Variable           = objJson.Variable;
         var DeviceId           = objJson.DeviceId;
         var RoomName           = objJson.RoomName;
         var Time               = objJson.Time;
         // Replace any spaces with underscore characters in DeviceNames
         DeviceName=DeviceName.replace(/ /g,"_");
         // We have different value-variables depending on the DeviceType that sent the msg
         // You need to extend this section for other sensors
         if (DeviceType.indexOf("HumiditySensor") !=-1)
             Influx_Key    = "humidity";
             Influx_KeyTag = "device=" + DeviceName;
             Influx_Value  = "value="  + objJson.CurrentLevel;
         if (DeviceType.indexOf("TemperatureSensor") !=-1)
             Influx_Key    = "temperature";
             Influx_Value  = "value="  + objJson.CurrentTemperature;
         // 2. Convert the retrieved data above into an InfluxDb-
         //    compatible format string.
         //    Influx text based line protocol:
         //        [key] [fields] [timestamp]
         //    Example: temperature,device=BedroomTemp value=11.3
         var InfluxFmtStr = Influx_Key + ',' + Influx_KeyTag + ' ' + Influx_Value;
         // 3. Create a new object containing our formatted InfluxDb
         //    string and return it, so it will be passed to the next
         //    component in the Node Red pipeline
         var DatabaseName = 'vera_db';
         var newMsg={};
         newMsg.payload = new Buffer(InfluxFmtStr);
         newMsg.url     = "http://127.0.0.1:8086/write?db=" + DatabaseName;
         return newMsg;
4.3 - Drag/Drop a http-inputnode and configure it
Method = POST
URL = http://127.0.0.1:8086/write?db=vera_db
Enable secure (SSL/TLS) connection = No
Use basic authentication = No
Return = a UTF-8 string
Name = http input req sending to InfluxDB
4.4 - Connect the device chain: MQTT → Function → HTTP
4.5 - Press the red Deploy-button
5. Test NodeRed-flow by publishing an MQTT message using the commandline tool
‘mosquitto_pub’. Verify the data is inserted in the InfluxDb database.
mosquitto_pub -t Vera/test -m ‘{“CurrentTemperature”:11.3,“DeviceId”:151,“DeviceName”:“BedroomTemp”,“DeviceType”:“urn:schemas-micasaverde-com:device:TemperatureSensor:1”,“OldCurrentTemperature”:11.4,“RoomId”:13,“RoomName”:“Bedroom”,“ServiceId”:“urn:upnp-org:serviceId:TemperatureSensor1”,“Time”:1478159673,“Variable”:“CurrentTemperature”}’
influx
use vera_db
show series
select * from temperature
select * from temperature where device=‘BedroomTemp’
[/code]
Here’s a screendump of my Node-Red flow.
[quote=“kodarn, post:76, topic:190658”]Interesting Work! :smiley:
Would it be possible to share the Node-Red flow?[/quote]
Hi @kodarn, it seems like you are making great progress on your MQTT deployment. In the spirit of sharing, here are a few pertinent details for my deployment and I am happy to provide any additional details that you would like… I am also using mosquitto to collect sensor measurements from 4 Veras running UI7 at different geographic locations. Each Vera reports into a local mqtt broker running on an RPI that is bridged to the central broker (SeapSpray) and they communicate using TLS/SSL over the Internet. The impetus is that the local MQTT broker will cache sensor readings whenever the Internet is down and then reconnect when the Internet is up at which point it will send all previous and current sensor readings/measurements to the central broker virtually eliminating any data loss.
To simplify the NodeRed transformation, I use the MQTT identifier Vera/(SerialNumber)/(ServiceName)/(DeviceId) so I can persist all measurements (i.e. ServiceNames) to separate InfluxDB named by SerialNumber. So I have a single measure transform for all incoming measures that are then split out into the respective databases.
I have attached a diagram of my deployment and NodeRed topology and here is the core measure transform:
// Transform MQTT payload into InfluxDB measure
// Topic is defined as Vera/(Serial)/(Service)/(DeviceId)
var measure = {};
var payload = new Array(2);
// Set the measurement for this measure (3rd element from topic)
// MQTT Client Topic Publish == Vera/(SerialNumber)/(ServiceName)/(DeviceId)
measure.measurement = msg.topic.split('/')[2];
data = msg.payload;
// Field first, with time converted to milliseconds
valueAsString = data[data.Variable];
if (!isNaN(parseFloat(valueAsString)) && isFinite(valueAsString)) {
    value = parseFloat(valueAsString);
} else {
    value = valueAsString;
payload[0] = {
    [data.Variable] : value,
    time            : data.Time + '000'
// Tags
payload[1] = {
    deviceId    : data.DeviceId,
    deviceName  : data.DeviceName,
    deviceType  : data.DeviceType.split(':').slice(-2)[0],
measure.topic = msg.topic;
measure.payload = payload;
// Update the status with the # of messages processed
var count = context.get('count')||0;
count += 1;
context.set('count', count);
node.status({text: count});
return measure;
Note, my core measure transform is designed to allow replay of external legacy events hence the ‘parseFloat()’ checks so not needed if you aren’t going to replay data and you don’t really need to create a new output measure, you can simply modify the input measure. This is working great for me so I haven’t taken the time to simplify further.
Cheers,
Bruce
