Moving to Z-Way, vera is crap.
I have had this network - 25+ nodes - running just fine several times, when all of a sudden all of the battery operated devices take a dump. I don’t care about battery life so I have set the wakeup timing down to 300 seconds for all devices with batteries. Even at that the devices sit there with a blue lite and “waiting for wakeup to configure device” for days. All of the devices seem to work ok, but I want this system to operate correctly and all of the configure problems are not correct operation.
I have healed this thing until I am blue in the face - nothing seems to get everything working as it should for very long. I did read about a check box that if unchecked would stop the 2am automatic heal - that didn’t seem to help so I am going to dump vera and move to Z-way.
Best of luck!
  • Garrett
If all of your routes to a device fail … it will still do a nightly heal to fix the dead device … sounds like you have a poor network topology … something that new software will not fix! More routing devices should solve your problem.
