Moving from Schlage/nexia to Vera3 - appliance modules?
Hey
I’m trying to convert my Nexia system over to a Vera3. I’ve successfully configured my new Vera3 and enrolled an Aeon 4 in1 sensor. That all seems well. The problems I’m having have to do with the two appliance modules and the two thermostats I had connected to the Nexia. (the Aeon was new and never connected to Nexia). I removed the appliance modules and the Trane 500B from the Nexia network using the hard remove button on the website. I also told the Trane 500B to leave the zwave network. I can’t seem to add them nor the Wifi based XL950 to Vera.
The Vera3 has very limited devices it has to select from. Are all these Trane and Schlage devices configured using “generic zwave” or other in the case of the XL950? How do you do that? Has anyone had success adding the schlage appliance modules? They have no visual feedback mechanism and there doesn’t seem to be an enroll/unenroll process. Any ideas?
I need to get the appliance modules running because they function as repeaters to extend the network over to the Trane zwave thermostat. I don’t know how to add the XL950. Any ideas?
Sorry for the basic questions - maybe there is a document somewhere a very technical newbie could get up to speed?
Thanks…
Update -
I found the Vera3 Documentation and Wiki from the forum page… duh! Sorry.
I also was able to configure the appliance modules by trying various standard appliance modules, on the assumption they all probably work about the same. They do! But, I’m still at a loss on how to get the two trane thermostats working. If I new what the thermostats that are supported look like, maybe I could find one that seems close and try that.
Any ideas?
Thanks again,…
Did you have any luck getting 950 Stat to connect to vera
