Moving from IRIS, few questions
I have had the iris system for over 2 years now and have loved it. Now with the 2.0 coming out it’s becoming a POS. Main issue being local-processing which from what I have read the Casa Verde system does this. I have the following devices and was wondering if they will work with the Verde hubs and which one I will need.
3 iris door sensors (will be 2.0 and from what i understand are zwave so they will work?)
1 iris motion sensor (same deal as the door sensors)
2 Radio Thermostat CT-101
1 GE Light Switch
1 First Alert Smoke Detector
1 Kwikset Deadbolt Doorlock
1 iris range extender (I don’t think this will work)
And the big one is a gen 2 keypad. My favorite part about iris is that it still feels like an alarm system. i don’t have to use my phone to set the alarm. Is that something that verde can do? I really hope i can use this system since iris has left me out to dry.
Thanks!
[quote=“46l281gt, post:1, topic:192444”]I have had the iris system for over 2 years now and have loved it. Now with the 2.0 coming out it’s becoming a POS. Main issue being local-processing which from what I have read the Casa Verde system does this. I have the following devices and was wondering if they will work with the Verde hubs and which one I will need.
1 GE Light Switch
Thanks![/quote]
Hi 46l281gt
Can you provide specific model numbers for your devices? Perhaps then we can get you some answers.
Z
The CT-101 will work, as will the GE switch and Kwikset lock. At least, to my knowledge, they are all Z-Wave. I have the Ct-101 and I don’t think GE makes anything BUT Z-Wave.
Anything branded Iris is likely to be ZigBee and not compatible.
First Alert should be Z-Wave. I have two - bought from Lowes - that are. Check the model number.
If your Kwikset has their SmartKey feature, consider replacing it. It is easily bypassed with little more than a screwdriver. Google it. I’d recommend Schlage.
This is the best place to look. Note: some of the Iris devices look identical to other brands’ ZigBee devices like the motion sensor, that is because they are made by the other companies.
http://getvera.com/compatibility/
