Move logs from USB to cifs?
Hi all,
I have cifs up and running for DataYour2 and this works well. I also send my Vera logs to USB. I would like to send logs to a Cifs mount instead of the USB since the USB can be a little troublesome on occasions.
As such:
  1. Is this possible? If so:
    a. Can I just mount the relevant folder as I do with the datayours2 storage cifs mount?
    b. If yes to above then is the relevant folder: ?root/tmp/log/cmh??
Thank you in advance for any help.
I run UI5 on Vera3
