I thought it might be useful to set up a thread to compare notes on alternatives to motion sensing with Vera2 (or Vera3), as there are some elements to the set-up that seem to take some tweaking. Since some of this seemed non-obvious (to me at least), shared experience might be useful to anyone involved.
First off, it seems there are fundamentally two choices I’ve come across: i) the HSM100 Z-Wave device; and ii) the Insteon 2420M. If one is focused fundamentally on motion, then the HSM100, which is 2x as expensive per unit, has a cost disadvantage. This can mount up quickly, if you have 10s of sensors in your home. I would welcome any input as to alternatives people have used that might be superior (at least in some ways).
The HSM worked for me (with Vera2) pretty easily and immediately. That said, it is not immediately obvious it is working, depending on how you have polling and wake-up timing set. However, if you leave it alone for a day or so, you’ll start seeing some tracking, e.g. via the dataMine plug-in. The temp resolution seems to be 1 degree F (not sure if any different in C), so any monitoring that logs only ‘when changed’ will need to wait for some movement.
If cost is no object, then the biggest challenge with the HSM100 seems to be battery life. I need to re-visit my settings (expect polling and/or waking up way too frequently), as I managed to kill my sensors 3x AAA batteries in a few days. I’m sure I have significant inefficiences just to confirm thing was working, but I’m also curious to know if anyone has implemented a ‘battery eliminator’ solution for HSM100, i.e. transformer plugged into wall. I couldn’t even get comfortable that the battery case was in series, i.e. 4.5 volts required – seems jumper on two of the batteries, and the third isolated separately (from quick resistance test).
The 2420M seems to have pretty reasonable battery life so far (few weeks, but with ‘always on’ occupancy mode set). We shall see. Biggest problem I have is with stability and programming via Vera2. I’ll get six or so of these sensors set up, and then after reboot (or something), the Vera2 seems to be ‘cleared’ of these devices, or they are back to their generic i/o initial state. Takes Vera2 quite some time (and sometimes seemingly never) to communicate adequately to get these devices identified as type ‘_Motion Sensor’. Again, comments welcome against this general experience. By comparison, the reliability of the data logs with Insteon-centic HouseLinc software is far better (but of course I’d prefer not to have a spare laptop always on for this purpose).
In any event, reactions to any of this welcome. Specifically, advice on optimized polling settings for HSM100 and/or battery eliminator options. And tips re: getting good communication between 2420M and Vera2 welcome. Are things considerably better with Vera3? Has anyone found the 3rd-party Insteon plug-ins provide a better base for the 2420Ms?
JohnR
