I would like to place a motion sensor on my washing machine so I can get a notification when it is done. I can never hear the bell go off and I would like for it to be able to sit on top the washer or dryer and send me a notice when it stops moving.
I am just a newbie as well so take this advice with a grain of salt.
So call motion detectors are actually passive infrared sensors so I don’t think that will work.
What I would do is hook up a a door sensor with a aux input to a relay run off the dryer buzzer.
I would be concerned that you’d get false positives.
That sensor is going to be a simple open/close type of sensor where it opens when it detects vibration and closes when there is none.
Think of this scenario:
Start washing machine… open
Washing machine pauses… close
Washing machine washes… open
Washing machine goes to spin cycle… open
Washing machine finished… close
You’d have to account for this through timers or some sort of logical counter, etc…
I think watching for load on the circuit would be a good attempt. Either a Zwave switch that monitors load, or using a whole home energy monitor dedicated to that line.
use any device capable of energy metering, use pleg to send a push notification, tts, flash a light or whatever when, current watts goes above 2 in my case, then back to 2 for >5 mins.
