Hello,
I would like to share my experience on the following devices as well:
- EZmotion Express Control 3-in-1
- Everspring SP814
Documentation
The topic is easy. The everspring brings a fair to good documentation while the EZmotion comes with a ridiculous and useless piece of paper. The only useful information is how to include the module and what kind of batteries it uses (in case you cannot figure it out yourself…)
Everspring SP814
First, I started with an everspring sensor and I have to say it does the trick pretty well.
The device was easy to setup and worked right away as expected. Only drawback compared to the 3-in-1, the everspring does ONLY motion. I heard it can beep, mine never did. I wish I could also disable or program the led inside the everspring module but it does not seem possible.
My SP814 is set with the following settings:
[ol][li]1 byte dec, 99[/li]
[li]1 byte dec, 3[/li]
[li]1 byte dec, 10[/li][/ol]
I am currently measuring over time how much battery these settings take, for now, it looks fair.
I have programmed a light to go off when the motion detector detects movement AND this is during the day.(!isnight()).
Express Control EZMotion 3-in-1
On the paper, a great device. First I tested the motion detection, the device seems to react very quick. It feels more snappy than the SP814. Inclusion was not of the easiest.
First I started, “to see”, with the settings set to “Stay Awakeon”. What should happened happened, it drained my batteries in no time (few days).
After that, I tried finding reasonable settings. Today I am using:
[ol][li]180[/li]
[li]3[/li]
[li]255[/li]
[li]50[/li]
[li]0[/li]
[li]255[/li][/ol]
The battery usage is now reasonable but I did not check over a period that is long enough to compare with the SP814.
The EZmotion brings back the temperature and the light level. Or at least it should. The idea is that it can be put grouped with a light and decide when the light should be turned on. This is how I understand that it should work. The sensor return a light level between 0 and 100. 0 is dark, 100 is bright. It is possible to define a threshold for the light level. I set it to 50 but it changes nothing. No matter if the current level is under or above, the light goes off anyway.
And that should not have anything to do with the Vera since the light and the sensor are in the same group so the sensor controls the light directly.
If you go this EZmotion to work properly, please let me know your settings and configuration, I would love to use this device but at the moment, I cannot recommend it.
Will
PS: Using a Vera with latest update.
