This is a dying technology.
http://www.007systems.com/sonos-audio-distribution.html[/quote]
I don’t think so, at least not for me. I don’t want a bunch of speakers just sitting around in all the rooms. I want in ceiling speakers. I know I could do the Sonos Connect Amps, but then all I’ve done is replace 1 multi-channel amp with multiple ones. I know that Sonos has better connectivity, but that comes at a price (both space and money). Perhaps Sonos should consider doing a multi-channel amp of their own (6 zones/6 channels, daisy chainable, with optional keypads with intercom). 1 unit would be a lot easier to swallow even at say $2-3k for the system.
As to the link you’ve provided, here are my responses to their “cons”:
They are very difficult to install.
Yes, but I feel they are worth the hassle.
The cost of these systems including labor can be in the many thousands of dollars.
Yes, but so can a complete Sonos system!.
The cost of labor alone can be 2 to 5 times that of the hardware.
Not if you do it yourself ;).
They are limited in the amount of rooms and inputs they use. Usually 6 inputs and 6 zones or rooms.
Actually, some of them allow you to daisy chain them. Some allow you to also have a “local” source for each room.
They usually require a keypad in each room, to be mounted on the wall of that room. Not as convenient as using your smartphone or tablet.
I find this a Pro, not a con. I don’t always have my phone on me. I don’t always want to have my phone/tablet on me. If I go to take a shower, I’d much rather have a keypad on the wall to use instead of bringing in my tablet and/or phone.
They are Difficult to upgrade if the technology changes.
I’m pretty sure that once you have the speakers in place and cat5/6 for the keypads (and of course you should loop the speaker connections at the keypads as well), then if the technology changes, I would think that it would be as simple as replacing the hardware and the keypads. Not really all that difficult. Not to mention, the manufacturers have a vested interest in making upgrades as simple as possible (using existing wiring).
They usually require an equipment room or a closet to install the controller.
Yes, you do. I don’t mind this. I have an equipment room already, so it’s not a con at all for me.
I realize that if you are only looking to do a few rooms that Sonos would be better, but if you want a full house setup (outside included) I think a ADS is better than using Pure Sonos (not that you couldn’t incorporate Sonos into your ADS).
Also, understand that I am not necessarily talking about the Monoprice one. I personally am looking at something like the Nuvo Concerto or similar system.
