Monoprice door/window sensor not working properly
My newly installed door sensor from Monoprice isn’t working. It does pair correctly and I see it as a door sensor in Vera.
It correctly detects a door open if started from untripped state.
When I close the door again it will switch to ‘closed’ and instantly back to ‘open’ again. I have to manually untrip the sensor by changing the appropriate variable for it to go back to ‘closed’ again. If I don’t do this it will just stay in ‘opened’ and only momentarily switch to ‘closed’ whenever I close the door.
I also had a garage door sensor from Monoprice before that was showing similar behavior. I thought it was broken so I returned it.
Any ideas? My VeraEdge is on 1.7.1248
It’s not the sensor. There seems to be a bug in UI7. GetVera fixed it for the PIR sensors but it still is there for the door/window and glass break sensor. I believe someone already reported this but I am not sure.
I am having this exact same issue. There are a couple of threads discussing it. I’m hoping for a fix soon!
Is there a way to adjust the sensitivity of the door and window sensor? If your system has these options try adjusting it to the desired outcome. If not then there may be a problem with the program of Vera. You should report it and have them fix your system. You don’t have to mess with the hardware as it will void the warranty.
assembly card circuit
