I just got the weather plug in working but I noticed that it isn’t updated often, looks like twice a day. Is it possible to set that to update once an hour?
It refreshes every 30 minutes. It writes a log entry into [tt]/var/log/cmh/LuaUPnP.log[/tt] each time it updates (or errors). You’ll want to check that log if you’re not seeing 30-minute updates.
If you want to make the 30 minunte interval customizable, then please file a Ticket in the code.mios.com system against the Plugin codebase.
