Modes - Can't Set Dimmer
For the different modes (Home, Away, etc) I could set the desired status of the locks. I also wanted to have certain lights turned on and set to a particular dimmer level. However, it never stays in “On” but returns back to “No Change”. This is happening with 3 different dimmers each a different brand. Considering this, it seems to me it’s not an issue of the switch but vera. Has anybody else experienced this? I am on v1.7.439.
Also is it possible that I turn on the light if it’s night? Basically, I want to add a condition for taking an action (like turning a light on). It doesn’t look like that works but I figured I ask just in case. It seems the upcoming PLEG might support such scenarios, though.
Hi maja,
This is a bug that will be fixed in our next firmware release this month.
Best Regards,
  • Andrei -
[quote author=maja link=topic=2911
Also is it possible that I turn on the light if it’s night? Basically, I want to add a condition for taking an action (like turning a light on). It doesn’t look like that works but I figured I ask just in case. It seems the upcoming PLEG might support such scenarios, though.[/quote]If not with PLEG, then look into return luup.is_night == true
Andrei, z-waver, thanks for the responses. This is helpful to know.
