Model HA14C switches
I purchased a Lot of 4 of these switches, and they don’t appear to be working on the Zwave network, I have tried to add them with my Vera system the light never flutters no matter what I do with the switches. Any possible suggestions>
@Nighthawk209,
Welcome!
The default suggestion is to try to exclude them first. (Using the Dashboard, if you can, and watch for messages in the status window that indicate whether the device was detected.) Then try including them.
(Exclusion is possible from any controller; it doesn’t matter whether the device was first (successfully) included with Vera.)
I have several of these and a few have very poor range. Vera would need to be right next to the switch for inclusion. Also, these switches need to be pressed for a full second, not just a tap, when including/excluding.
Tried all the things you suggested, and they are in and working fine.
Thank you.
