Mochad plug in on veraedge can't detect
So I purchased the new veraedge and I have an older CM15A from x10. Installed mochad on my pc. Installed plug in on veraedge. Set ip to point to pc on vera. Set variable for plc control to 1. Set one binary device and removed the defaults. The only message I get is can’t connect to device on the vera. I am able to send commands from another pc to the pc running the mochad. If I do a nc x.x.x.x 1099 I am able to connect and issue working commands.
The mochad plugin has not yet been updated for UI7. I’m having the same issues you are. The original author did reply a few weeks ago and say he might try to update the plugin, so I’m holding out hope.
Here’s the thread on the plugin: [url=http://forum.micasaverde.com/index.php/topic,7463.105.html]http://forum.micasaverde.com/index.php/topic,7463.105.html[/url]
Oh OK I was going crazy this past week and thought there might be something wrong with the vera. Not 100 % sure why a GUI redesign would cause a plug in not to work but then I haven’t tried making a plug in myself just yet. Thanks for the update.
