When I’m trying to browse to the Mobile Vera portal (https://findvera.com/mobile) and try to login, I get a 404 - Not Found.
This occurs from both the Text Version & the Graphical Version.
The non mobile version works, but obviously is painful on the mobile.
Works fine. You have to run a Luup firmware AND install the required plugin at Devices → Luup plugins → Install/uninstall plugins → (Basic Mobile Web Interface or Smartphone Web Interface)
