Hi – I just added my 3rd Vera, and it autoupdated itself to UI6. I thought I’d just bite the bullet to see how it goes, and for the most part things are working. However, when I try and access with AutHomation in remote mode, I get “MMS Device Not Authenticated”. Any guidance if there is something in UI6 that needs to be set to allow devices to access it?
I am running Authomation 3.3.1.4
The servers are set to vera-us-oem-relay12.mios… and vera-us-oem-relay11.mios… I did not explicitly enter them into the fields (since I did not know which to enter) when I set up the connection. I do have the MMS checkbox set.
Thank You
