Running the old ADD plugin, I am seeing the following:
Device # 1 Scene Controller has neighbor # 8, but device # 8 does not exist or it isn’t a Z-Wave device (its device_num_parent isn’t 1).
Device # 1 Scene Controller has neighbor # 10, but device # 10 does not exist or it isn’t a Z-Wave device (its device_num_parent isn’t 1).
I verified the fact that 8 & 10 do not exist. Is there a simple way to tell Vera that these are not valid neighbors?
This is a remote unit and I really hate doing a heal on something I don’t have easy access to. Not sure how it got this way to start with.
Its been this way from some time, I would swear I have done a heal in the past and it still seems to be a problem. (Not that heal would fix this anyway).
Any suggestions would be appreciated… thanks!
[quote=“Les F, post:1, topic:187531”]Running the old ADD plugin, I am seeing the following:
Any suggestions would be appreciated… thanks![/quote]
Hi Les –
I’m having the same problem on a remote Vera3 running UI5 (1.5.622). A number of the neighbors appear blank for HSM-100s. I have about 8 HSM100s and half are blank neighbors and have have defined neighbors. All seem to be working. It doesn’t matter how many heals I do they still remain blank (although the report, under repair, shows them as functional and they seem to be reporting).
