Hi Guys,
First ever question/post on here so please go easy. I’ve already searched for a couple hours for the answer to this, but haven’t been able to find it.
Currently my setup includes numerous Danfoss Living Connect Z-wave TRVs. After much fiddling, they seem to be working quite well. There is one issue I’ve not yet been able to sort yet though.
I some of my rooms, I have more than one radiator and thus more than one TRV. I wish to get each of the TRVs in the same room to mirror each others settings. So, if I change the setpoint manually, or via Vera, I’d like the other TRVs in the same room to copy the new setting. This would negate me needing to manually change each TRV in turn.
Can anyone think of a simple work-around?
Thanks for your help.
Pete
I’m not sure about simple… One problem is, to stop the TRVs chasing each other, the logic would have to know which one to use as master. I don’t think you could just use a who-changed-first logic because it would override any manual change that you made after Vera sent a new setpoint. It may be that the simplest solution is to pick one TRV in a room as master and slave the others from it.
Once you have decided on the rules, I recommend you install Program Logic Event Generator (PLEG) and use that to implement the logic. See PLEG Basics for an introduction to PLEG.
Hi Rex
Thanks for the input. I’m fairly new to z wave. However, I have successfully associated my dual channel boiler controller with a z wave wall thermostat. I wondered if two danfoss units might have a similar approach so that if a temp was manuaply set on one, it would automatically be mirrored on the other (independant of set-points sent from Vera).
I understand that any waypoint sent from Vera can a easily be sent to multiple danfoss TRVs simultaneously. I just wondered if I could configure each ‘same room’ TRV to mirror a change made via a TRVs physical buttons. i.e. TRV 1 temp has been changed via its physical buttons, therefore TRV follows reads new setpoint and follows suit (all independantly of setpoints sent from Vera alone).
Thanks for the PLEG link to. Just about to have a read.
Cheers
I figured it out and have it working in my house with two AC units, it’s quite simple actually.
Set up a scene that triggers on a temperature change (say set point changed to lower than 85F) to your primary thermostat
add this Luup:
– get the setpoint temperature in the Primary Thermostat
local lul_temp = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“CurrentSetpoint”, 22)
–22 is my primary thermostat
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint=tonumber(lul_temp) },4)
–4 is my secondary thermostat
You do the reverse on the other. You have to be careful that your controllers are not chasing each other, so remove your ‘secondary’ TStat from your HVAC automation. Just let it follow the lead of the master.
