MiPi-1wire "plugin"
This is a script to be able to use Raspberry Pi connected 1-Wire temperature sensors with your Vera.
If you want to do this first setup using 1-wire temperature sensors with your RPi. There are many of them out there and it is pretty easy. After that download my script from GitHub - jheizer/MiPi-1wire: MiCaseVerde RaspberryPi 1-wire provider Install apache, nginx, or what ever your preferred webserver for linux is and have the script output a file to it’s root directory. The script will generate an xml that I designed from looking at the code for the OW-Server’s plugin.
So once you are able to access http://RPi/details.xml you can then install the OW-Server plugin seen here OW-SERVER - EDS One Wire interface plugin You can ignore all the OW-server stuff and just enter the ip address of your RPi in the settings in vera. This plugin will take care of all the Vera stuff and generate devices for each 1-wire sensor attached to the RPi.
Note that this is in no way associated with OW-Server or the OW-Server plugin creator. If you have any issues with this at all please don’t bug them. I just reverse engineered what I needed to make this work with that plugin instead of having to learn how to create my own vera plugin that did the same thing.
Here you can see some of my sensors graphed out in the datamine plugin.
Great! :smiley: But ???
I only get “No new devices to add”.
Any clue what’s missing?
Got it!
The /details.xml must be in the root folder of the www server.
Thanks for the nice work!!!
This is the perfect excuse to get a rasp pi.
Can you tell me (or link) what hardware you are using and how it interfered with the pi.
[quote=“HouseBot, post:3, topic:178166”]Got it!
Thanks for the nice work!!![/quote]
Good to know this ended up being useful for at least one other person. I should have noted that it had to be in the root directory since we are just emulating another device and that is where it has it.
[quote=“jimpapa, post:4, topic:178166”]This is the perfect excuse to get a rasp pi.
Can you tell me (or link) what hardware you are using and how it interfered with the pi.[/quote]
If you google for DS18S20 and raspberry pi numerous guides will come up. Right now I open emulated the temp sensor code. If there are others people need access to I can see about adding them as well.
ok, got it … thank you!
