Mios/zwave Routing
should i use Mios routing or zwave routing? whats the difference
You should use the default; MiOS routing.
Z-Wave networks utilize a source routed system. Z-Wave nodes will build their own routing tables based on neighbor advertisements and other factors. But, the Z-Wave routing system has a few faults that results in suboptimal routing, low processing power is partly to blame for this. So, MiOS came up with their own method for calculating routing tables. Using the MiOS method, Vera calculates its own routing table rather than relying on the Z-Wave table in the Z-Wave dongle. It is usually the better option.
See this thread for more details on routing.
