Can I change my mios username? I do not see an option in the web portal. Would I want to add the username (under a different email) and then delete the user I wanted to change. Then go back to the second username I just added and change my email back?
thanks,
Mike
[quote=“rinconmike”]Can I change my mios username? I do not see an option in the web portal. Would I want to add the username (under a different email) and then delete the user I wanted to change. Then go back to the second username I just added and change my email back?
thanks,
Mike[/quote]
No, the username cannot be changed.
You can create a new second account with distinct email address. You also can also allow multiple users access to your Vera.
You cannot delete the account as far as I know, so your scenario you would need to modify the current account to another email before creating the second account. This is done from cp.mios.com dashboard after logging in
