I would like to know if it is possible to update the visibility of a plugin on the store after its creation ?
My idea would be to make the plugin available to me only in a first time to check that everything is ok, and then change its visibility to “Public”.
When I create a plugin, I can select “Owner” as visibility, but then when I edit the created plugin, the visibility field is not present.
Hi lolodomo,
There is no need to change the visibility for your plugin. Upload the new file in “Plugin files” tab. Use the “Plugin files/Plugin files/Update button” for new revision of an existing file, or use “Plugin files/Add files” for other new files. Next step will be to “Publish” the new version(“Versions/Publish” section). Now, you will find it in “Versions/Versions” section. From here you can install it on your Vera, test it and if everything is alright, you can add a release and submit for approval your new version. Until it is approved, it will not be visible to other users.
Hope this will help.
Bests,
- Andrei -
