Mios MArket Place
I’m running 1047 but when I go to the market place I cant access any pages passed page 1. I get the following:
Not Found
The requested URL /sid-363293148e860611d6d78e1098785f0e was not found on this server.
Anyone else get this?
I’ve seen this, but only via cp.mios.com. When I run it “locally” against Vera it works ok. Can you confirm that you’re running it “remotely” in this case.
From memory, I might have also had to have the “[ x ] Show Beta” checkbox set, but I might also be imagining that.
I runnign from cp.mios.com and i have the checkbox checked. I will check through a local address tonight. It’s worth a shot.
Thanks.
I just checked remotely (cp.mios.com) using the same firmware, without the checkbox checked, and I could view all three pages.
Make sure you “wait for it”, it does take quite a while to come up and change from page to page.
It goes right to the error no loading.
So i unchecked the box for beta plugins and now I can get to the other pages. I swear ive done this mulitple times before and it did not work…
I may not have tried it on this new release version and it was on the beta version. Oh well.
Correct, it’s specifically related to the implementation of the checkbox option:
 [ x ] Show Beta
not working correctly over cp.mios.com. There are a few of these cases like this. From memory “View Plugin Source” also breaks when attempted over the remote service.
I’ll try from a local address tongiht then and see if there are any I am missing.
um so how do you get to the market place in UI 4?
Theres a frame I believe the second one down and a plus sign to the right of it.
