When not directly connected to my network and I attempt to login to my Vera through MiOS.com it states I have the wrong login/password. However, I’m using the same exact login/password I utilize when I’m directly connected. I even tried resetting my password just to be sure and I am still unable to login through MiOS.com. Has anyone else run into this??
mios.com is totally different account and relates to their software developers account.
The kicker…
You can still use;
MiOS for UI5 and previous
However the new remote login should be through Vera Controls (new site)
Thanks! I had no idea I was even trying to login from the wrong site because I was pretty certain I had used MiOS.com to login remotely in the past. The new Vera Controls website works for me and I was successful in logging into my Vera remotely.
[quote=“agoodman82”]@Brientim
Thanks! I had no idea I was even trying to login from the wrong site because I was pretty certain I had used MiOS.com to login remotely in the past. The new Vera Controls website works for me and I was successful in logging into my Vera remotely.[/quote]
Yes mios.com was previously used but not for a long time. It was then changed to cp.mios.com or cpui5.mios.com as they changed structure. But it means you are still sane and your memory is working…
