mios.com remote control
I am noticing several posts about the mios servers being down. I am able to logon to mios.com, but once I try and access my system, I get a “data not loading”. Is this related, or is this a network setup issue? The local IP address of my vera2 that shows up in the mios dialog looks accurate (I used that address to access Vera locally before I left my house).
not sure if you’ve resolved this issue but I had the samething a few months ago and basically what happened is the IP address changed on my network (power loss in the neighborhood) and my DSL modem changed IP addresses, not sure why this affected Vera but all I had to do was power cycle Vera and it worked again when away from the house.
not sure if this will resolve it but may help if you haven’t resolved it already.
Thanks – turns out I had to “activate” from the local GUI. It was working fine before though, that’s the strange part. Perhaps there was a firmware update behind the scenes. Who knows? It’s working now.
