Trying to setup an account on https://cp.mios.com/ keep on getting the following error message, when trying to register the gateway, have a Veralite unit.
I am trying to connect to your unit using local network connection.
You may get a security warning since access point web server doesn’t support https.
One moment while I try contact it on your local home network.
If you still see this message after 15 seconds, please reset your unit, wait one minute then click here
Thanks again for all your help
Hi there, to all.
I am new to this to, and after i sucessuly configure all my definitions and one plug (it’s the start for me)
I tried to reconnect on my internet explorer, and does not pass the point (very first menu) showing the message that can’t find any controler on my network. But if I put the direct IP it show the UI but I can not login, because it change it to mios page.
And sometimes shows (ERROR: 966dee3d92)
Can someone give some help…to a newbi?!
many thanks in advace and sorry about my english.
Best regards,
Pedro Madeira
