Yes, wiered situation!
Mios contacted me recently and told me that my IP address is blacklisted because I was making too many requests, seems thousands of them, on their cloud servers. Consequence, I lost access to cp.mios.com, sta1 and sta2.mios.com, and all servers required to locate my Veralite on their servers. These servers are needed by the Concierge app to be able to locate and link my Vera.
As a result, I made a network trace and found that Vera Concierge, the java local application, was hammering their servers with a lot of requests of this kind:
2018-07-10 19:44:56 I:VeraConnect.VeraGateway:URLConnection:https://sta1.mios.com/locator_json.php?username=xxxxxxx
Probably trying to locate my vera box.
Before this happened, I had a problem with my veralite that stopped working and was not able to register to the Vera cloud servers. Because Vera Concierge lost the access to my box, It seems to try to locate it in a very aggressive manner and floods consequently the vera cloud servers.
This needs a fix please, or I and may be others in the same situation, will not be able to get access remotely to their Vera box and will not be able to use Vera concierge.
I am running UI5 on my Veralite by the way, and Concierge was just working fine before this happened,
Thanks for your help
