When changing tstat temp value it one need to delete old value with multiple key strokes … can you make the field just a type over???
It should already be doing this. However it looks like it can be hit or miss. Which is odd as I am using the appropriate call to select all of the text in the box. I just made some changes to the code to make it work all of the time. So this should be fixed in the next release.
- Garrett
@Garrett … tks!
