I accidentally bought a normally closed sensor for mimolite and it show my garage door in the opposite state as it actually is…any clues on how to reverse the status to show it correctly?
thanks
thanks
[quote=“nickman2025, post:1, topic:180052”]I accidentally bought a normally closed sensor for mimolite and it show my garage door in the opposite state as it actually is…any clues on how to reverse the status to show it correctly?
thanks[/quote]
Are you talking about the actual MimoLite device? The Mimo has two relay contacts, NO and NC. You may need to switch the wire to the other contact .
The normal open is for the actual control of the garage door that your showing. The + and - relay the status of the door and right now it relays the opposite of it being open or closed as it is normally closed loop and the magnet opens it. I need the opposite and would prefer not buying new hardware.
To clarify,
You are using the Mimo plugin and Mimo’s Binary Sensor device is showing Tripped when the magnetic sensor is in contact and the door is closed, correct?
thanks[/quote]
I bought the right sensor according to the directions and it was backwards. I contacted the maker of the app (which I suggest you to also do) and never found a way to reverse it. I’m sure its a fairly simple software fix but it’s over my pay grade and I never got anyone to figure it out for me. Needless to say I went out and bought a different contact sensor that has 3 wires. So it would be wired either way. I’m not longer in need of a solution altho it would have saved me a bit of time and money at the time.
I think the maker of the app said he was working on a an update that would let you choose. But haven’t seen or heard anymore which is why I suggest you put your interest and maybe with enough people he will update it.
Here is the thread I started on this a while back ago.
http://forum.micasaverde.com/index.php/topic,22755.msg153458.html#msg153458
Here is the last PM I got from the creator. Please contact him for help.
[quote=“lylavoie”]Hello Jim,
I know there is a potential issue with supporting both connection types, i.e. a normally open and/or normally closed contacts. Mine are definitely wired normally closed.
What I would like to do is update the plugfest to allow the user to select this setting as an option/configuration. But, I haven’t had a chance to work on this yet. It’s not a straight forward part I know how to program right now. The plugin architecture is a strange combination of XML, JSON, and LUUA code, and I need to dig into what I can put where to make not only the status correct, but also the events as well.
I haven’t forgotten about this, but I need a chance when I can spend a solid couple of hours working on it.
Cheers,
Lincoln[/quote]
Notice you say you have a normally closed sensor and he says his is the same way. There is something else causing this glitch, because some people with normally closed sensors it works fine. But I’m not the first (look in his app reviews) that has said they have normally closed but it reads backwards. Also if you look in the directions for install.
http://homeautomation.lavoieholdings.com/mimolite-garage-door-plugin
It says “Wire the door sensor, so the contacts are “normally closed” when the door is closed.” (Which this is how 99% of alarm sensors are and it’s much harder to find one that’s reversed like the one I ended up using)
This takes the guess work out of is the sensor normally open when the magnet is energizing it or not.
This also means when the contacts are opened the door should show opened and when you paperclip between the contact it should show closed. But mine shows reverse. First few PM’s he swears the few of us that are having problems are just installing the wrong sensor. Which I know I’m not according to his directions.
I’m not sure if it’s a MIMOlite thing or an App thing, but a few of us get this backwards reading.
Do you really have a backwards sensor according to his directions? Or are you one of the few that just gets a backwards reading with the right sensor?
Because there is 12volts at the Mimo, and if you do’t want the hassle of removing the sensor you put in, you can leave the existing contact in place if you just wire in a little relay to flip the voltage.
they are a few dollars at radioshack.
There should be a software solution to this, @integlikewhoa is right.
It would be nice if MCV would allow you to enter into advanced settings to change a sponsor sensor from NO to NC and vice versa.
I’m having a similar issue, but different. I’m using a normally closed magnetic contact for the sensor (ie. It’s SHORTED OUT when the door is closed).
However, mine ALWAYS shows the OPEN icon. The green light on the mimolight is properly showing GREEN When the door is up and shuts off when the door is closed. Also verified everything with an ohms meter.
Any ideas? How do I get a hold of the developer?
[quote=“Theboob, post:9, topic:180052”]I’m having a similar issue, but different. I’m using a normally closed magnetic contact for the sensor (ie. It’s SHORTED OUT when the door is closed).
Any ideas? How do I get a hold of the developer?[/quote]
You have another issue. I don’t think the green light has anything to do with it either. There is no status led for the switch that I know of. I would try to re-install the app or could be a hardware problem. But that’s not an issue with the software programming.
[quote=“integlikewhoa, post:10, topic:180052”][quote=“Theboob, post:9, topic:180052”]I’m having a similar issue, but different. I’m using a normally closed magnetic contact for the sensor (ie. It’s SHORTED OUT when the door is closed).
You have another issue. I don’t think the green light has anything to do with it either. There is no status led for the switch that I know of. I would try to re-install the app or could be a hardware problem. But that’s not an issue with the software programming.[/quote]
It definitely has a status light on it indicating the status of the input. It’s green when the circuit is “open” and off when the circuit is “closed - shorted”. I’m starting to think the app isn’t working. I’ll have to see if I can somehow see some log data that shows whats coming back form the mimolite. If it’s correct, the app is not working. If it’s not correct, the hardware is screwed.
Now…how the heck to I see the data coming back…hmmm…
Well an easy test to see if the mimo is working is to change garage door apps. There is another one in the app store that works or you can uninstall the mimo garage door app and install the regular MIMO app to atleast see status updates. Not sure if you tired uninstalling and re-installing same app either.
[quote=“Theboob, post:11, topic:180052”][quote=“integlikewhoa, post:10, topic:180052”][quote=“Theboob, post:9, topic:180052”]I’m having a similar issue, but different. I’m using a normally closed magnetic contact for the sensor (ie. It’s SHORTED OUT when the door is closed).
Now…how the heck to I see the data coming back…hmmm…[/quote]
[quote=“integlikewhoa, post:12, topic:180052”]Well an easy test to see if the mimo is working is to change garage door apps. There is another one in the app store that works or you can uninstall the mimo garage door app and install the regular MIMO app to atleast see status updates. Not sure if you tired uninstalling and re-installing same app either.
Now…how the heck to I see the data coming back…hmmm…[/quote][/quote]
Alright. I’ve gone back to the standard mimolite app (the older one). So in the instructions, it says goto the advanced tab of the new device added for the mimo app. Then it says to search for the “MIMO_Devices” and enter the device id of the mimo device. In my case, it’s 5. However, in the instructions for the app, they show something like “300,3”. So do I enter “300,5”??? The instructions for everything so far suck. Lots of details missing.
Also. Once I figure that out, how do I actually see the value of the SIG1 value???
Thanks.
[quote=“Theboob, post:9, topic:180052”]Alright. I’ve gone back to the standard mimolite app (the older one). So in the instructions, it says goto the advanced tab of the new device added for the mimo app. Then it says to search for the “MIMO_Devices” and enter the device id of the mimo device. In my case, it’s 5. However, in the instructions for the app, they show something like “300,3”. So do I enter “300,5”??? The instructions for everything so far suck. Lots of details missing.
Thanks.[/quote]
Oh I see. In the docs, they use “300,3” because they seem to have 2 mimos installed. I’m guessing that based on the pictures they show later.
Regardless, my "generic sensor is always showing “0”. I think my mimo is screwed.
your sensor may not be producing a voltage, I believe that is why it is always reading zero volts. It may be either an open circuit or a closed circuit, in which case you need to attach a relay to create a voltage.
Now that you have the Mimo devices set up, try to connect a (1.5 or 9Volt) battery to the inputs of your Mimo and test it that way, or just jump the power inputs and look for 12Volts reporting back to Vera.
Weird. I gave up on the “MIMOlite Plugin” plug in and went back to the " MIMOlite Garage Door Contoller" (whoever wrote that misspelled controller). The “MIMOlite Garage Door Contoller” now seems to be getting whatever event it’s looking for and is toggling the “garage door” icon when the SIG changes from open to closed (shorted).
However, now it’s like other users have reported where the icon is reversed. Shows the garage door closed icon when the circuit is OPEN and the garage door open icon when the circuit is shorted.
Note that my sensor is normally closed when the magnet is engaged. Obviously whoever wrote the plugin did it the reverse (which would be weird). Even though the documentation for the plugin says “1.Wire the door sensor, so the contacts are “normally closed” when the door is closed.”
I still don’t understand why this plugin seems to be getting whatever event it’s waiting for and the other one is not. I suspect it is like you are saying. The older plugin is actually looking for a voltage above a certain value to trigger it. Whereas this newer plugin is reading (or receiving) some other event that is toggling the door icon.
Do you know how to get a hold of the author of the plugin? It would be a great learning experience for me to get the code and see if I can fix it up. I’m a s/w developer so I want to figure this stuff out anyway. Maybe I’ll just write my own. But it would be great to see some sample code…
great to see you have it working.
No offence, but the creators name is on the app when you download it and the code is in the app that you also downloaded. I have also posted his name and a copy of a PM from him in about the 5th post down…
Therefore my thinking is if you were able to fix the issue, you would also know these simple things. But I could be wrong, knock yourself out.
EDIT: Sorry it was the 7th post down on the first page.
Not to be too pedantic about it being a noob and all, but “normally closed, or open” describes the operation of a relay or contacts, and not state. Normal means status in an inactive state, so “Normally closed when the door is closed” is a contradiction if the magnet activates the switch when the door is closed.
What I believe is needed is a magnetic switch that is “normally open”, meaning it closes when the magnet activates it. This would be installed so activation happens when the door is shut. This will provide a proper “fail-safe” indication, in other words, if the switch fails for some sort of reason, you will get an open indication on the door (unsafe), instead of a false closed (safe) indication. I believe most magnetic switches used in alarm and security systems are Normally Open for this reason.
[quote=“PromptCritical, post:19, topic:180052”]“Normally closed when the door is closed”
What I believe is needed is a magnetic switch that is “normally open”, meaning it closes when the magnet activates it. [/quote]
That is correct and that’s how a normal contact works. But as we said this is backwards to that. If the circuit is closed (magnet installed) it reads open door. If you cut the wire, disconnect it, or move the magnet away(open circuit) it reads closed door.
It’s merely a software problem. If you use another garage door app it reads correct with a normal alarm contact. This software reads backwards to what it should that’s all. Just need a software fix to flop it around and a normal contact would work and would read correctly. If not you need to wire it backwards which is not secure… But I don’t use it for security purpose have an alarm on the house with a different contact.
