I’m trying to migrate my parents from their X10 system to a ZWave system run through the MiCasaVerde Light device.
On their existing X10 devices connected to lamps, if they want to turn on a lamp manually but the X10 unit is set to “off”, they can twist the knob on the lamp a couple times and it would basically trigger the on/off in the X10 unit.
Is there something similar on the ZWave side? Do all of the Lamp modules available for ZWave work this way, or only a few, or none? They aren’t going to want to reach behind the couch to press the button on the ZWave lamp module to turn on their lights when they don’t have their phone or remote available.
Thanks in advance!
Many of the Zwave lamp controllers have load sensing - feature you describe, but it usually needs to be enabled via a Zwave-set parameter. For instance, with the popular Jasco/GE 45602, setting parameter 29 to 1 will do the trick. Setting parameters is handled by the “device options” tab on a device in Vera.
A lot of the plug in modules have a on/off button on the module, and they also report the status to the controller, so you can see and use the state they are in in your logic or see remotely what state your lights are
Thanks for your response! I am curious about the RP200…I see many label it as an equivalent to the GE 45602; does anyone know if it does the load sensing feature?
Yes. The RP200 has load sensing, too. I’ve got several. I just set variable 29 on them and it worked. They work just like the Jasco. And correction - the variable is added on the “device options” tab. I’ve updated my initial post.
