Micasaverde.com - Down?
I am not able to access micasaverde.com - I am getting error messages from Cloudflare.com. Am I alone?
Ken
Same thing here I’m afraid
Gesendet von meinem GT-P3110 mit Tapatalk 4
On line now. Did feel all home alone for a while there!
I’m a newbie…does this happen often?
Ken
If you search the forum for similar topics, you can get an idea of how often it happens. It does not happen all the time, but once in awhile. I believe cloud flare is a load balancing service.
  • Garrett
@kengrant,
Welcome!
They did make improvements over time and presumably the number of users went up as well; I’d say in general it’s more reliable than it was before…
I was not able to access the server since 14 hours ago until now. The down time is really long.
I still cannot access micasaverde.com , is it working for anyone, please advise
i can access the sites, but the vera has trouble acessing apps.mios.com
every reload takes 10 minutes now …
I can’t connect to apps.mios.com either
It has been down most of the day. it started working a couple of hours ago. When it is down, none of my push notifications (prowl) seem to work either. uggh.
However, for those need to do something locally, you can still login using your local network. However, the new setting will not be backup at this moment.
