Loving homewave but wondering how I can control the colours on my Mi-light bulbs. I have installed the vera plugin which works fine but when I select the colour lamp control in homewave it doesn’t show the lights as an available device. If I select use the dimmer control I can select the lamps and control them but not the colour.
got your PM - and have signed up for the BETA - unfortunately can’t reply to your PM, don’t have enough posts yet. Have emailed through your website. Hope thats ok.
I have installed in my veralite the WW/CW led bulb (white model) with V3 bridge.
Over MIOS (web) the plugin RGB+W works.
In my homewave version - 1.55 - do not work
I can test for you, if you re-add me to beta test group.
you need some testing ?
i have a few RGB and white/white lamps here. (no RGBW)
oh one thing, (but thats not exactly count to this thread)
the miLight lamps do keep the dim level, in homewave its then really hard to find out a lamp is on or off if the dim level is low.
se attached example:
“Light Office” is Turned on at 22% … “Light Sofa” is off.
would be nice to have the dimmer behave like switches (as an option) … and display SwitchPower instead of Dimlevel on the ring.
