Merten CONNECT
I have two dimmers… I see my dimmers have the following id and altid (I’m reading from dimmer advanced tab):
dimer a) id:3 … altid:17
dimer b) id:4… altid:18
I’m trying to define an association between two dimmer and my Merten Connect MOVE. when I go to the setting of the button > Device Options > add group [1] > Set… I can see my dimmers listed there and I pick those that I want to be associated with my button and put number 4 (which is the configuration value for toggling/dimming/shutters single surface) in the textbox next to them. next I’ll chose “configure node right now” from setting of the button and by triple tapping on the button I can program my button successfully.
now my association doesn’t work because when I chose my dimmers I see their id is picked up in “associations” > “set to” section…
I see the following in front of Set: 3.4,4.4
I remember once I did this before and altid of the dimmers were picked (instead of id) and I saw 17.4,18.4 in set section and it was working perfectly all right.
I just wonder if anyone can help me there?
Thanks,
