Hello,
I just bought the new Co2 sensor from MCOHOME, I can include it in the vera, (UI7), but then I don’t have any info on the CO2, temperature and humidity in the vera.
Is there a way to set it up correctly?
I thought that standard zwave devices were able to discuss together and have at least basic information.
From my point of view, it’s a very important sensor to have in the house to monitor air quality.
Hello, I have the same problem. My config is: VERA EDGE, UI7, 1.7.2139. I bought MH9-CO2-WD. I see 4 devices after inclusion:
“Temperature Sensor” (works fine),
“Humidity Sensor” (works fine),
“Generic IO”,
“_GET_LANG(generic_sensor,sensor)”.
There is no information about CO2 level. I bought this device exclusively for the measurement of CO2 - to control air vent.
somebody of skilled people can help with a way to get CO2 level from sensor? (may be temporary, before the release of official support)
So I just bought one, as I wanted to know the CO2 level in the living room. After inclusion I got 4 devices out of it: temperature, humidity, and 2x _GET_LANG(generic_sensor,sensor). One of the latter sensors actually shows the CO2 level, the other once showed a 1 which I assumed was the VOC level, but now it shows nothing. 3 out of 4, with the 3 most important ones working.
