MCO touch switch
My MCO touch switch switch - MCO_TPS314 - has suddenly started playing up with Vera - this was before the latest firmware update. It works physically, and the status changes are reflected in the PLEG scenes I have, but I cannot control it from Vera - either from the UI or from PLEG.
I have unpaired it - factory reset and repaired it to no avail.
Anyone else got one of these - and had any problems?
Cheers
Rob
Edit - I meant to say - Vera appears to change status of the switch if I alter it (which is detected by PLEG) - but nothing physically happens.
Hi Rob,
I’m interested to try the MCO, from where did you got it?
AM
Hi Vesternet supplied.
(And replaced it under warranty and seems fine now)
