Is there a limit to the number of variables that can simultaneously be watched via [tt]variable_watch[/tt]? MAX_CALLBACKS? If there is a limit, [tt]luup.variable_watch[/tt] should return an error code.
I’m asking because I’m trying to watch all HaDevice1 variables for all my devices, but I think that some variables (e.g., battery reports (BatteryDate)) are missing from my logfile.
Theoretically you should be able to watch an unlimited number of variables. Check the logs to see if those variables are really monitored: look for luup_variable_watch added hook to device.
Found a bug in GDL V0.7:
GDL V0.7 doesn’t support device category 1, but HSM100s are ComboDevice1s with device category 1 and the battery variables are components of the HSM100 parent devices …
The distance between the 3-in-1 HSM100 sensors and Vera is minimal for the AZ_3-in-1 HSM100, but the AZ_3-in-1 is the device with the least frequent battery report. Strange.
