It’s a bit scatter/gather at the moment: wiki and (this) board, plus marketplace; I think apps.mios.com is a collection effort, sourced from said locations.
[quote=“chixxi, post:3, topic:169672”]Yes, actually you can install plugins, it just always installs the wrong one. If I try for example you “Heliotrope Plugin” it installs “PhilipsDVD”.
So I hope that’s because of UI4, although that doesn’t make a lot of sense…[/quote]
Happens the same here!
I’m running a Vera2 with ui4 and I always get the wrong plugin! :o I’m trying to install the Heliotrope, DVR Install Utilit and another one…
Can someone please confirme if it’s possible to install these with ui4?
I might be a bit tired to understand correctly but the problem is just the way the plug-ins are being “published” so to speak, but are the plug-ins made to UI5 compatible with UI4?
Thank you Mcv!
Would you be so kind to point me to the 3 files used by the plugin called DVR? I want to try it and see if it can work with my dvr that I have with 3 cameras. If I can manage to make it work it will help some of us that have the same problem as me - watch the DVR signal with Vera2.
