ManufacturerInfo and VersionInfo
Does anyone have some data or links on where i can find what devices and manufacturer these numbers are ?
for example this fibaro device:
ManufacturerInfo 271,2304,4096
VersionInfo 3,3,52,22,22
NodeInfo 26,27,31,32,33,60,70,72,73,7a,85,86,
what do the numbers represent ?
i know the last numbers on the version info are the firmware version which is 2.2 for this device but the rest i have no clue…
need a way to distinguise the different devices that can be on a vera in order to make different device UI for my remote control app
Have a look here:
http://www.pepper1.net/zwavedb/?sort=name&sort_type=desc&filter_cmd_class=&filter_frequency=&filter_language=&filter_manufacturer=116&filter_generic_class=
ManufacturerInfo 271,2304,4096 →
271 = 0x010F <— Manufacturer
2304 = 0x900 ← Product Type ID
4096 = 0x1000 ← Product ID
And 26,27,31,32,33,60,70,72,73,7a,85,86, are probably the Command Classes:
http://wiki.micasaverde.com/index.php/ZWave_Command_Classes
If you use the InfoViewer Plugin, the Command Classes should all be listed for the device, when you click on the device’s link. What is this Fibaro device by the way? I couldn’t find it in the database above.
A question you can help me with - what does the Green Wave reality powe rboard have listed under: Device → Advanced Tab → ManufacturerInfo?
thanx !
yup i have the infoviewer but it doesnt show z-wave properties through remote login :-/
the fibaro device is a RGBW controller see here : [url=http://forum.micasaverde.com/index.php/topic,15132.msg119612.html#msg119612]http://forum.micasaverde.com/index.php/topic,15132.msg119612.html#msg119612[/url]
the Greenwave Reality 6-port node has
manifacturerinfo : 153,3,4
capabilities : 211,156,1,4,16,1,L,R,B,RS,|32,37,39,50:2,86,96:2,112,113:1,114,117,133,134,135,
nodeinfo : 20,25,27,32,56,60,70,71,72,75,85,86,87,
multichannel capabilities : 1,16,1,32,37,50,117,2,16,1,32,37,50,117,3,16,1,32,37,50,117,4,16,1,32,37,50,117,5,16,1,32,37,50,117,6,16,1,32,37,50,117,
versioninfo : 3,3,33,4,21
from info plugin :
Powernode 2 → zw node: 17 Capabilities: 211,156,1,4,16,1,L,R,B,RS,|32,37,39,50:2,86,96:2,112,113:1,114,117,133,134,135,
Listens : yes
Routes : yes
Has a Beam receiver : no
Can transmit a Beam : yes
Routing slave : yes
Security device : no
32 BASIC
37 SWITCH_BINARY
39 SWITCH_ALL
50 METER
96 MULTI_CHANNEL_V2, MULTI_INSTANCE
112 CONFIGURATION, CONFIGURATION_V2
113 ALARM
114 MANUFACTURER_SPECIFIC
117 PROTECTION, PROTECTION_V2
133 ASSOCIATION, ASSOCIATION_V2
134 VERSION
135 INDICATOR
