Manual z-wave route: are multiple routes possible ?
I can setup manual route for device, but sometimes communication fails.
Is there a possibility to set multiple (alternative) routes to device ?
will you tell me how to set up this manually?
You can set it up in ‘Device Options’ tab. By default is ‘undefined’.
thank you :smiley:
Xav,
Would you mind showing an example of the syntax you use for setting the manual route. I have not seen it documented, and the MiOS help links near “Manual Z-Wave Route” in the UI are not functional in the version I have.
Dot separated node list.
I tried it, but the result was not pretty… any idea what might have happened? Node 10 is between node 7 and the controller, and should be a reliable intermediary.
01 10/23/11 22:02:15.414 ZWaveNode::CurrentRouteFailed node 7 device 37 position -1 route 10.0.0.0 hop -1 (from 0) <0xc04>
2011-10-23 22:02:15 - LuaUPnP Terminated with Exit Code: 245
2011-10-23 22:02:15 - LuaUPnP crash
David
David,
My experience says that the geometric position is less important than the “radio visibility”.
Go into: Toolbox → Z-Wave device → Repair
And analyze existing repair report or start new repair task to get a new report.
It should help you to choose intermediary node.
