Thanks for the quick replies, so that brings up my other problem then. Why does my veralite think my sunset is 1:51 pm when I use it in a scene for turning on a light?
Is there anyway to check what time my veralite thinks sunset is?
Open the user_data with: http://:3480/data_request?id=user_data&output_format=xml
Search for a tag named . Below this tag search for that scene. You should see a list with the timers. Look for the next_run attribute of that timer (schedule).
Use a web tool like this one to convert the timestamp in a readable local time.
I did run the timezone fixer script, and deleted the scene and re-did it for :15 after sunset and it worked yesterday at the expected time.
Thanks for your help.
