Greetings,
I’m trying to turn on my dimmable light, ID 7, using the sample provided in the wiki in the ‘Test Luup code (Lua)’ screen. I press Go and get ‘Received empty response’ and the light does not turn on.
The code is:
lu_CallAction(“urn:upnp-org:serviceId:Dimming1”,“SetLoadLevelTarget”,{ newLoadlevelTarget=“30” },7)
which is straight from the wiki, only changing the 6 to 7.
What am I missing?
Thanks,
Brian
I’m not a coder, but a quick search in the wiki revealed a possible suggestion:
Try luup.call_action instead.
Examine this Luup snippet:
local lul_arguments = {}
lul_arguments[“newTargetValue”]=“0”
lul_resultcode,lul_resultstring,lul_job,lul_returnarguments = [b]luup.call_action/b
This may be an indicator that MCV re-wrote (or normalized) portions of the Luup API, a discussion I recall seeing elsewhere in the Forum.
Hope this helps, though I’m clearly grasping at straws.
Brian,
Can you provide the hyperlink to the wiki.micasaverde.com page containing the incorrect sample? This will help folks to get it corrected to the newer syntax.
The “mapping” is on post #6 of this thread:
http://forum.micasaverde.com/index.php?topic=1561.0
If you see an example of the form lug_xxxxx or lu_xxxxx then it’s an older style example that needs to be converted.
One example I ran across, where the “older style” code is mentioned…
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events
(See section 3.1 “Misc actions”)
To find this example, I “cheated” the wiki’s search utility by looking for “upnp-org:serviceId” and examining each instance it found. (Search is not terribly adept at finding instances of “lu_callAction” for some reason.)
Would you mind being the one to edit the wiki in this case? I might screw something up, since I don’t understand Lua/Luup at all. :-\
done, just applied the literal string translation. I’ve assumed these calls are still the same in terms of parameters etc, since I dont use Luup scene code… yet.
Outstanding. Looks like you updated the wiki. Using that new sample code, I was able to dim my dining room light.
The wiki I was using was the LUUP Scenes Events.
Thanks,
