Hi everyone!
I had a luup code running smoothly for months, after update to Vera 1.7.4903 (7.31) it stopped. It is fragment of my code:
-- DRZWI
function czujnikDrzwiOff()
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget", {newTargetValue = "0"}, 24) -- przedpokoj2
function czujnikDrzwi(device, service, variable, lastvalue, newvalue)
if (newvalue== "1") then
local status, mode = luup.inet.wget("http://127.0.0.1:3480/data_request?id=variableget&Variable=Mode",0)
if (tonumber(mode)==2) then
luup.call_action("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget",{ newLoadlevelTarget="100" }, 48) -- roleta salon
luup.call_action("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget",{ newLoadlevelTarget="100" }, 35) -- roleta kuchnia
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","SetHouseMode", {Mode = 1}, 0)
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget", {newTargetValue = "1"}, 24) -- przedpokoj2
else
luup.call_delay( 'czujnikDrzwiOff', 120)
luup.variable_watch("czujnikDrzwi","urn:micasaverde-com:serviceId:SecuritySensor1","Tripped",82)
I think that something is wrong with variable_watch. Can anyone say if it is ok for new version? For now i see that my door sensor is recognized as ‘DoorSensor’ - not ‘SecuritySensor’.
