Hello,
I have a PLEG instance which switches everything off , checks if window is closes , door is closed and locked , garage door is closed , than give me a notificication.
But I noticed that when I execute this PLEG ( VS_alarm_on) I get shortly afterwards a LUUP restart.
I have no idea why.
Attached the DEBUG log , I clicked the ( VS_alarm_on) virtual switch at 21:47:?? I get a luup restart at 21:48:53
Although I think the LUUP restart happened a bit earlier , since when I start the this PLEG , 30 seconds later I should recieve a notification , I never received the notification.
I also attached the logic report in PDF.
How do I best troubleshoot where the problem is , or is it already obvious to someone?
Thanks,
Cor
