I’ve uploaded 2x XSLT files to code.mios.com that can be used (with a freestanding XSLT Tool) to “transform” an XML Device file, from SQRemote’s backup, into the requisite I_xxx.xml and D_xxx.xml files. Next, i?ve upload these files to Mios like attach. The I_devDSTV is an original file and the other corresponds to transform process uploaded to Mios.
But, after the procedure, the icon was not been created. I repeated the procedure many times but the problem still on.
After you’ve done the conversion, you’ll end up with:
I_dev595798956.xml
D_dev595798956.xml
These are all that you need, there is no need to manually create anything else. Instead, you simply use these two [Generated, Plugin] files to create an IR Device in Vera.
Then, you need only associate this IR Device with the appropriate [SQBlaster] IR Transmitter in the Settings UI of the IR Device you just created (see screenshot)
