Luup code to check after some time if a sensor is open or close
Hello ,
I have a bit of an issue with my gate. Since it is quite far away I installed a second vera (lite) nearthe gate with a 95 meter UTP cable.This vera lite is controlled ( slaved) bij a vera 3 in my house.
For my gate I have installed a fibaro relais , and configurd it , so when activated it goes on for 3 seconds and therafter automatically off ( parameter 4 I believe).
I creathed a scene, when activated it activates the relais and after 90 seconds it activates again.
Occasionally about once every 10 times the colsing doesn’t work , I try to figure out why , but I am unable and I cannot get my network to function better.
Not really a problem but i would like to know the gate is open or close , which I will do with a universal sensor from fibaro and a microswitch, It will tell me (hopefully) when the is opened , when the gate is open for more than 2 minutes.
-When the gate is open , I want vera alerts to give me a warning. ( no problem setting this up)
-Can I use the trigger function of the device to know if the sensor is open more than 2 minutes , after that giving me a warning via vera alerts.?
When the scene is activated to open and close the gate and the gate is open more than 120 seconds , can a LUUP code be installed ( or so) that a retry will be done to close the gate ?
thanks,
Cor
Anything can be done in LUA … Just need to use the luup.call_timer function.
I am sure you will find examples if you search for this.
But this would be a lot easier with the Program Logic Event Generator plugin.
