[quote=“TimAlls, post:40, topic:168307”]Thanks Henk,
[code]1. HTML report for devices
- No header line for colums
- Only 1 device is shown
- Difficult to read dus to narrow columns
[/code]
I added the Excel output to help with the problem. The JSON outputs vary widely as to the column formats and I can’t keep up with the variations from Firmware to firmware. My solution is transfer the information into a spreadsheet and let the user edit the format to fit his system and firmware. I want to move on to the bigger task at hand…code generation and a PC based UI for touchscreen computers and laptops.
Please explain only one device is shown…Is the program not detecting all your devices?
I rewrote my code to read older firmwares so I am hoping I didn’t break something in the process!
I regards to Coding, I am new to Luup coding so I am relying on code donations from other programmers…no offers yet.
I am hoping some Newbies will try out my example and let me know if the program helps bridge the fear of adding Luup code to their scenes.
We will see!
Regards
Tim[/quote]
The HTML report only shows 1 device (no others) in my particular case the DAD device.
As you might remember, im on 1.1.1245
more remarks;
Unable to close the app unless by going to the first tab and click quit… major annoyance!
